105
Re Hide columns using javascript on UltraWebGrid
Hi,Can you tell me if the following is possible.I have designed a Ultra Web Grid using the following code (see below). My question is, Depending on the value of DropDownList, I want the user to enter data in either column ValueDropDown, ValueDate or ValueDate.Is it possible to hide the columns I don't need using Javascript after selection of DropDownList, or is there another way to achieve this without having to hide columns.  Thanks for your helpKevin   <igtbl:UltraWebGrid ID="uwgAttributes" runat="server" Width="100%"><Bands><igtbl:UltraGridBand><Columns><igtbl:UltraGridColumn Hidden="True" Key="AttributeID"><Header Caption="AttributeID"></Header></igtbl:UltraGridColumn><igtbl:UltraGridColumn DataType="System.DateTime" EditorControlID="wdSkillsEditor"Format="dd/MM/yyyy" Key="From" Type="Custom" Width="20%"><Header Caption="Gultig Vom"><RowLayoutColumnInfo OriginX="1" /></Header><Footer><RowLayoutColumnInfo OriginX="1" /></Footer></igtbl:UltraGridColumn><igtbl:UltraGridColumn DataType="System.DateTime" EditorControlID="wdSkillsEditor"Format="dd/MM/yyyy" Key="To" Type="Custom" Width="20%"><Header Caption="Gultig Bis"><RowLayoutColumnInfo OriginX="2" /></Header><Footer><RowLayoutColumnInfo OriginX="2" /></Footer></igtbl:UltraGridColumn><igtbl:UltraGridColumn DataType="System.Int32" Key="Name" Type="DropDownList" Width="20%"><Header Caption="Attribute"><RowLayoutColumnInfo OriginX="3" /></Header><Footer><RowLayoutColumnInfo OriginX="3" /></Footer></igtbl:UltraGridColumn><igtbl:UltraGridColumn DataType="System.DateTime" EditorControlID="wdSkillsEditor"Format="dd/MM/yyyy" Key="ValueDate" Type="Custom" Width="20%" Hidden="false"><Header Caption="ValueDate"><RowLayoutColumnInfo OriginX="2" /></Header><Footer><RowLayoutColumnInfo OriginX="2" /></Footer></igtbl:UltraGridColumn><igtbl:UltraGridColumn DataType="System.Int32" Key="ValueDropDown" Type="DropDownList" Width="20%" Hidden="false"><Header Caption="ValueDropDown"><RowLayoutColumnInfo OriginX="3" /></Header><Footer><RowLayoutColumnInfo OriginX="3" /></Footer></igtbl:UltraGridColumn><igtbl:UltraGridColumn Hidden="false"><Header Caption="ValueInt"><RowLayoutColumnInfo OriginX="2" /></Header><Footer><RowLayoutColumnInfo OriginX="2" /></Footer></igtbl:UltraGridColumn></Columns><AddNewRow View="NotSet" Visible="NotSet"></AddNewRow></igtbl:UltraGridBand></Bands><DisplayLayout AllowDeleteDefault="Yes" AllowUpdateDefault="Yes" BorderCollapseDefault="Separate"Name="uwgAttributes" RowHeightDefault="16px" RowSelectorsDefault="No" SelectTypeRowDefault="Single"StationaryMargins="Header" StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed"Version="4.00" AllowAddNewDefault="Yes" AutoGenerateColumns="False" CellClickActionDefault="Edit"><FrameStyle Width="100%" BorderColor="#A1B1C8" BorderStyle="Solid" BorderWidth="1px"></FrameStyle><ClientSideEvents BeforeExitEditModeHandler="uwgAttributes_BeforeExitEditModeHandler" KeyDownHandler="MappingGridKeyDownHandler" BeforeEnterEditModeHandler="uwgAttributes_BeforeEnterEditModeHandler" AfterExitEditModeHandler="uwgAttributes_AfterExitEditModeHandler" /><EditCellStyleDefault BorderStyle="None" BorderWidth="0px"></EditCellStyleDefault><HeaderStyleDefault Wrap="True" ForeColor="White" BackColor="#89A3C8" BorderColor="#5E7BA5" BorderStyle="Solid" BorderWidth="1px" Font-Size="11px"><Padding Top="2px" Right="2px" Bottom="2px" Left="2px" /><BorderDetails ColorLeft="137, 163, 200" ColorTop="137, 163, 200" /></HeaderStyleDefault><RowStyleDefault BorderColor="#A1B1C8" BorderStyle="Solid" BorderWidth="1px" BackColor="White"><Padding Top="2px" Bottom="2px" Left="3px" /><BorderDetails ColorLeft="White" ColorTop="White" /></RowStyleDefault><GroupByRowStyleDefault BackColor="Control" BorderColor="Window"></GroupByRowStyleDefault><GroupByBox><BoxStyle BackColor="ActiveBorder" BorderColor="Window"></BoxStyle></GroupByBox><ActivationObject BorderColor="" BorderWidth=""></ActivationObject></DisplayLayout></igtbl:UltraWebGrid>
  • 28464
    Thanks for writing. This could be possible using the CSOM (Client Side Object Model) of our UltraWebGrid product. Please, take a look at our online help for CSOM, and especially the Columns client-side object
    http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR3.5/html/WebGrid_Column_Object_CSOM.html
    you can play with the setHidden method - this seems close to what you need.
    You can also search the forum for threads employing setHidden for sample code:
    http://forums.infragistics.com/search/SearchResults.aspx?q=setHidden
    Please, let me know if this helps.
  • 8680
    Suggestion: Improve legibility by using line breaks and indentation.
    I'm no JavaScript guru, but you can find a lot of information on working with grids on the client side in the online docs.
    HTH
