I am using C#, .Net2.0 and Infragistics 7.1. I want to make a License entry field where there are 4 infragistics text boxes each with maxlength = 4. I want to know if there is a property that I can use so that the user does not have to enter tab to go from one box to the other when the user has reached the max length.
I need to incorporate this feature soon. Please reply asap.
Thanks!
Thanks. It works good!
Yes, this is perfectly doable using the CSOM (client-side object model) of the WebTextEdit product. The idea is to use the client-side TextChanged event, check the length of the text typed and if it is 4, set focus to the second editor. Here is some sample code:
<igtxt:WebTextEdit ID="WebTextEdit1" runat="server" MaxLength="4"> <ClientSideEvents TextChanged="TextChangedHandler" /> </igtxt:WebTextEdit> <igtxt:WebTextEdit ID="WebTextEdit2" runat="server" MaxLength="4"> </igtxt:WebTextEdit> <script language="javascript"> function TextChangedHandler(editor, newValue) { var editor1 = igedit_getById("<%= WebTextEdit1.ClientID %>"); var editor2 = igedit_getById("<%= WebTextEdit2.ClientID %>"); if (newValue.length >= 4) editor2.focus(); } </script>
More info on CSOM can be found in our online help located here:
http://help.infragistics.com/NetAdvantage/NET/2008.2/CLR3.5/
Hope this helps.
