190
How to get original cell value on client?
If I first time change cell value on client in webgrid, I can get get new value: cell.getValue() and previous value: cell.getOldValue().
For example:
1) original value: 10
2) I change it to 11, after this: cell.getValue() == 11 and cell.getOldValue() == 10
3) I change it from 11 to 12, after this: cell.getValue == 12 and cell.getOldValue == 11 and so on...
Is there way to get original cell value from server? i.e 10 in my case
  • 8680
    I'd create a separate, hidden column containing the original values.
  • 28464
    As far as I know the grid does not have anything built-in to support that. I would guess that you may need to write some additional javascript code - for example you can create a new array and the first time you setValue for the cell you can store the original value in a javascript array (the key could be the ID of the cell - it is unique). Then, on subsequent changes, if the javascript array has already value set of this key, then just do nothing - and then restore the original value from the javascript array.
