Hi
We need a C# solution here. Can't use JavaScript.
I have a page with two grids. The main grid is a combination of hierarchy rows and flat rows and is unbound. The user will select rows in the main grid and click an Add button to copy the rows from the main grid to a second grid. This second grid is flat.
My code is traversing the parent rows just fine. What I want to do is check to see if a parent rows has children, then cycle through the children checking to see if they are selected. If selected, copy the data to the second grid and continue processing.
I can't figure out how to traverse the children rows in band 1. I found code that enumerates the entire band but is not exactly what I want.
Thanks for any help!
Terry
Thanks very much for your reply and answer. My routine is working great now!
Hello Terry,
I believe you can take advantage of the HasChildRows property and the Rows collection of each row. For example:
foreach (UltraGridRow row in UltraWebGrid1.Rows) { if (row.HasChildRows) { foreach (UltraGridRow childRow in row.Rows) { // do something } } }
Sample code in a real-world scenario using these properties / collections can be found in this forum thread:
http://forums.infragistics.com/forums/p/7105/29448.aspx#29448
