we open a workbook (having protection and a password for it) with IG excel engine. After writing data to some cells we then save the workbook with a different name.
This copy is still protected, but doesn't have a password for the protection anymore. The user can simply press the "unprotect Sheet" button and is not not asked for a password.
This is a huge problem for us.
Regards
Hi Divya,
No problem, we can upgrade to the latest version and see if that fixes the issue.
Thank you for your prompt reply!
Cheers,Ben
That was a bug 260985 logged for version 18.1 and fixed in all above versions. We dont have workaround for that ,you would have to upgrade the application to apply the fix.
Hello Divya,
We appear to be seeing a similar issue using an older version of the Excel component (WinForms16.1.20161.2033)
If we write to an existing worksheet in an existing workbook, the password for another protected worksheet is the same workbook is removed.Is this a known issue that was fixed, or is there a workaround?
Thanks,Ben
Hello ,
I have created a private case CAS-200054-B1C8B0 with you in order to share the sample and having easy communication.
Getting this error attaching the file here. Tried different browsers.
