I would like to ask you if the following scenario can be solved with AJAX functionality:
I have web grid (table) and each row contains delete action. When user clicks on delete icon then table row should be deleted, ideally without page refresh but only with web grid refresh (AJAX).
My current solution is over action listener. It works fine but the whole page must be refreshed.
<h:commandButton image="images/icon_remove.gif" value="#{DATA_ROW.id}" actionListener="#{assetController.removeAssetGroupListener}" />
It would be nice to have a NetAdvantage commands with AJAX support.
Thank you,
ANECT
Thank you.
Second solution is what I wanted to have.
Anect
And here I can offer another implementation that does not bind you to the necessity of setting the value attribute with the id of the row and so you can give it an arbitrary value like Delete in this example:
In JAVA:
public void onPressDelete2(ActionEvent e){
RowItem item = (RowItem) e.getComponent().getParent().getParent();
Clients client = (Clients) GridView.getDataRow(item);
while(it.hasNext()){
clientsList.remove(client);
In JSF:
<ig:link value="Delete" smartRefreshIds="grid" actionListener="#{webGridSelectionBean.onPressDelete2}"></ig:link>
Regards!
Hi, Anect!
I can offer you one implementation that in no case claims to be the most effective:
String id = (String) ((HtmlLink)e.getSource()).getValue();
Iterator it = clientsList.iterator();
Clients client = (Clients)it.next();
System.out.println("Record " + client.getId() + " will be removed!");
System.out.println("Record " + client.getId() + " was removed!");
<ig:link value="#{DATA_ROW.id}" smartRefreshIds="grid" actionListener="#{webGridSelectionBean.onPressDelete}"></ig:link>
I have table (grid view) and there is button for deletion on each row. When user clicks on the button then I would need transfer object's ID on certain row.I need information which object I should delete.
Or is there any other possibility how this do it?
Could you, please, explain what parameters and where you want to transfer?
Thanks!
