Is it possible to put the UltraWebGrid in a repeater control? I am getting the following error message:A participant named ctl00$cphBody$rptrDetail$ctl00$uwgWorkCodeDetail already exists in the collection.Parameter name: participant
It should be possible to put the WebGrid inside of a repeater so I am not sure what problems you are having.
However, what are you putting the grid in a reapeater for? It is a hierarchical structure so there should not be any reason to do it.
Let me know the version of NetAdvantage you are using and the reason for using the repeater control and I will see what I can do.
