345
Getting Datakey Field Value Of a Row
How Can I get the data key field value of a row in Ultrawbgrid when i click a button in templated column in that row.
I am using vs 2005,Infragistics NetAdvantage 2008.1 CLR2.0.
Can any one please send me the solution .Thanks in advance
  • 28464
    You can use the CommandArgument property of the button and set it to the same valiud is the TemplatedColumn. Example:
     <igtbl:TemplatedColumn Key="CustomerID">
        <CellTemplate>
            <asp:Button CommandArgument="CustomerID" ID="Button1" runat="server" onclick="Button1_Click" Text="Button" />
        </CellTemplate>
    </igtbl:TemplatedColumn>
        protected void Button1_Click(object sender, EventArgs e)
            Button button = sender as Button;
            string dataKey = button.CommandArgument;
