If have this markup code in my PageMaster.master:
<asp:LoginView ID="LoginViewMenu" runat="server"><LoggedInTemplate> <ignav:UltraWebMenu ID="AppMenu" runat="server" ImageDirectory="~/ig_res/" JavaScriptFilename="" JavaScriptFileNameCommon="" LeafItemImageUrl="" ParentItemImageUrl="" StyleSetName=""> <ignav:Items> <ignav:Item Text="Home"></ignav:Item> <ignav:Item Text="SBD"></ignav:Item> </ignav:Items> <ignav:Levels> <ignav:level index="0"></ignav:level> </ignav:Levels></ignav:UltraWebMenu></LoggedInTemplate>
<AnonymousTemplate><ignav:UltraWebMenu ID="AppMenu" runat="server" ImageDirectory="~/ig_res/" JavaScriptFilename="" JavaScriptFileNameCommon="" LeafItemImageUrl="" ParentItemImageUrl="" StyleSetName=""> <ignav:Items> <ignav:Item Text="Home"></ignav:Item> <ignav:Item Text="Login"></ignav:Item> <ignav:Levels> <ignav:level index="0"></ignav:level> </ignav:Levels></ignav:Items></ignav:UltraWebMenu></AnonymousTemplate>
</asp:LoginView>
The possbily missing other UltraWebMenu childs possibly required are not there, because I cannot edit the whole thing in the designer (VS 2008, SP1). I added another menu to the content placeholder section, same issue: it gets not rendered and the .designer.cs variable UltraWebMenu1 is null.
Update: It seems to be "only" a "menu cannot be designed using VS designer if it is placed at a .master page" issue.
Infragistics2.WebUI.UltraWebNavigator.v8.2, Version=8.2.20082.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
