538
TargetURL and groupby functionality
I am using NetAdvantage 2007.1 on .Net 1.1 and i am having following problem:
The TargetURL property is lost after a group by. I use the code found in the documentation:
UltraWebGrid1_InitializeRow(sender,
  Infragistics.WebUI.UltraWebGrid.RowEventArgs e)
e.Row.Cells[1].TargetURL = "http://www.google.com/search?hl=en&q=" + e.Row.Cells[1].Value.ToString();
This works really great as long as you don't group the records in the grid. As soon as you group the rows, the TargetURL is reset and the hyperlink does not work anymore. There seems to be no way to trap the rows as they are being reinitialized neither on clientside nor on serverside because neither of these events are firing. The only event firing is the GroupColumn event on the server, from this event i do not seam to be able to get to the information on the grid as it is empty (I am using AJAX functionality to fill up the grid).
Has anyone experienced this and found a solution?
 Best Regards
 Peter
