This is my first project with ultrawebgrid.
I have an ultrawebgrid from which I delete rows using a postback event. When the last record is deleted I get a nullreference exception from the grid. Looks like its something to do with the viewstate.Here is the stack trace
[NullReferenceException: Object reference not set to an instance of an object.] Infragistics.WebUI.UltraWebGrid.UltraGridRow.GetRowLevel(Boolean thruGroup) +109 Infragistics.WebUI.UltraWebGrid.UltraGridLayout.System.Web.UI.IStateManager.SaveViewState() +821 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.SaveViewState() +74 System.Web.UI.Control.SaveViewStateRecursive() +187 System.Web.UI.Control.SaveViewStateRecursive() +106 System.Web.UI.Control.SaveViewStateRecursive() +106 System.Web.UI.Control.SaveViewStateRecursive() +106 System.Web.UI.Control.SaveViewStateRecursive() +106 System.Web.UI.Page.SaveAllState() +168 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1099
Can anyone help me figure out what I am missing when I am setting up the grid and deleting using the post back.
Thank you
Sam
This sounds like one for Developer Support. You can create a user support "incident", free of charge, at: http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
That will usually get you a reply within a week. For best results, attach a working application based on the Northwind database that illustrates your problem. After that, the reply is sometimes "We have determined that this is a bug and we have reported it to the development team." In which case, the next hotfix may or may not include a fix to your problem. Or they may simply tell you how to fix your problem.
