755
web grid with buttons on each row
I have the following table:
<body>
  <f:view>
    <h:form id="assetOverviewForm">
        <h:outputText value="#{gui['assets.overview']}" styleClass="heading2"/>
      <ig:gridView
           dataSource="#{assetOverviewController.allAssets}"
           pageSize="10">
        <f:facet name="header">
          <h:outputText value="#{gui['assets.listHeading']}" />
        </f:facet>
        <ig:column sortBy="publicId">
              <h:outputText value="#{gui['asset.id']}" />
          </f:facet>
          <h:outputText value="#{DATA_ROW.publicId}" />
        </ig:column>
          <ig:column>
            <h:commandLink action="#{assetDetailController.showAssetDetail}">
              <h:graphicImage value="images/buttonDetail.gif" style="border: 0px" />
              <f:param name="id" value="#{DATA_ROW.id}"/>
            </h:commandLink>
            <h:commandButton image="images/icon_remove.gif"
                action="#{assetOverviewController.deleteAsset}" value="#{gui['delete']}"
                onclick="if (!confirm('#{gui['asset.removeConfQuestion']}')) return false; else setIdForRemoving('#{DATA_ROW.id}');">
            </h:commandButton>
          </ig:column>
      </ig:gridView>
      <h:inputHidden id="assetRemoveId" value="-1"></h:inputHidden>
      <h:commandLink action="#{assetController.showAssetAdding}">
          <h:outputText value="#{gui['asset.addNew']}" />
      </h:commandLink>
    </h:form>
  </f:view>
</body>
Functionality should be as follows: each row contains two commands for detail and for deletion. Confirmation dialog must be opened before deletion-operation.
When there is only button for deletion then everything works fine - user clicks, confirmation dialog is opened. But when I add commandLink then it doesn't work - no confirmation dialog is opened and form is submitted. Also table sorting doesn't work with two commands.
I found out that this is because JS error - "curForm is undefined". It seems that JSF engine createdwrong page ?!?
Please I would very appreciate any help.
Thank you in advance,
ANECT
