I have a vertical IG menu in a left-of-page <div>, the ID of which identifies the CSS style. It has a single pixel right border and a light grey background:
When I click on a top-level node that has a child item, the screen is re-rendered thus:
The black border has disappeared below the menu flyout and the grey background has turned white in the <div> area below the menu.
The following pertains:
Here is the declaration of the menu:
<div id="leftnavbar"> <ignav:UltraWebMenu ID="LeftMenu" runat="server" CssClass="vertMenu" BorderCollapse="True" ExpandEffects-Type="Slide" WebMenuTarget="VerticalMenu"> <Images><XPSpacerImage Width="1px"/></Images> <ExpandEffects Type="NotSet" ShadowColor="#888888"></ExpandEffects> <MenuClientSideEvents ItemClick="LeftMenu_ItemClick"></MenuClientSideEvents> </ignav:UltraWebMenu></div>
Here is the definition of the CSS style that defines the containing <div>:
leftnavbar { position: absolute; left: 0em; top: 90px; font-size: small; font-weight: normal; width: 225px; border-right: 1px solid Black; float: left; padding-left: 0px; font-family: Verdana, Geneva, Arial, Helvetica, sans-serif; height: 100%; background-color: #e3e6eb; text-align: left; margin: 1px;}
Any suggestions or assistance would be gratefully received.
Kind regards
Paul
MS VS2008 Pro. IG for Web 2008v1. C#
Found it.
There must be something about describing a problem in simple terms that triggers the "solution centre" in one's own brain.
This is the CSS style for the menu itself.
.vertMenu{ width: 225px; text-align: left; color: #333333; background-color: #E3E6EB; font-family: Verdana, Geneva, Arial, Helvetica, sans-serif; font-size: x-small; font-weight: bold; border: none; z-index: 888888; margin: 0px; padding-left: 5px;}Notice that the width is exactly the same as for the containing <div>.
So, make the menu width 224 rather than 225 so that it fits within the <div> and the problem goes away. Obvious really. Needless to say, I feel a bit of a chump. Nonetheless,I hope that this posting may help someone else with the same issue.
