395
Controlling Editing of a Grid Cell
  I have Editable Grid. In that there are some editable columns. In some rows, I want this column should behave as readonly. How can we conditionally control editable behavior of a grid column.
Vinay
  • 1579
    You can achieve this behaviour of the grid by simply adding some JavaScript to your page. I have slightly changed one of our examples on WebGrid (Cell Editing - Client Events) so that the enteringEditMode event is canceled under some conditions.
    In JSF:
    <body>
    <f:view>
    <h:form>
    <f:verbatim escape="false">
    <br />
    <br />
    <textarea id="eventDumps" cols="60" rows="10"></textarea>
    <br>
    <input type="button" value="Clear"
    onclick="document.getElementById('eventDumps').innerHTML='';"/>
    <script type="text/javascript" >
    var el = document.getElementById("eventDumps");
    function EventHandler(sender, args, eventType){
    if(!el) return;
    if(!sender) return;
    var cell = args.getCell();
    var outStr = "Source: " + cell.getGrid().getId + "[" + cell.getIndex() + ", " + cell.getRowIndex() + "] EventType: " + eventType;
    el.innerHTML = el.innerHTML + outStr + "\r\n";
    el.scrollTop = el.scrollHeight - el.clientHeight;
    function EnteringEditMode(sender, args){
    if (cell.getRowIndex() % 3 != 0){EventHandler(sender, args, "EnteringEditMode");
    else{
    args.set_cancel(true);el.innerHTML = el.innerHTML + "EVENT CANCELED!" + "\r\n";;
    function EnteredEditMode(sender, args){EventHandler(sender, args, "EnteredEditMode");
    function ExitedEditMode(sender, args){
    EventHandler(sender, args, "ExitedEditMode");
    function ExitingEditMode(sender, args){EventHandler(sender, args, "ExitingEditMode");
    </script>
    </f:verbatim>
    <ig:gridView dataSource="#{cancelEvent.list}" pageSize="10">
    <ig:gridActivation></ig:gridActivation>
    <ig:gridEditing enableOnMouseClick="double" enableOnActive="false"
    enableOnKeyPress="true" enableOnF2="true" editMode="cell"
    updateMode="row"></ig:gridEditing>
    <ig:gridClientEvents enteringEditMode="EnteringEditMode"
    enteredEditMode="EnteredEditMode" exitedEditMode="ExitedEditMode" exitingEditMode="ExitingEditMode"></ig:gridClientEvents>
    <f:facet name="header">
    <h:outputText value="Employee List"></h:outputText>
    </f:facet>
    <ig:column>
    <h:outputText value="First Name"></h:outputText>
    </f:facet>
    <h:outputText value="#{DATA_ROW.firstName}"></h:outputText>
    </ig:column>
    <ig:column>
    <h:outputText value="Last Name"></h:outputText>
    </f:facet>
    <h:outputText value="#{DATA_ROW.lastName}"></h:outputText>
    </ig:column>
    <ig:column>
    <h:outputText value="e-mail"></h:outputText>
    </f:facet>
    <h:outputText value="#{DATA_ROW.email}"></h:outputText>
    </ig:column>
    <ig:column>
    <h:outputText value="Phone number"></h:outputText>
    </f:facet>
    <h:outputText value="#{DATA_ROW.phoneNumber}"></h:outputText>
    </ig:column>
    </ig:gridView>
    </h:form>
    </f:view>
    </body>
    In that example you check if the row number is divisible by 3 and these rows cannot be modified because we cancel the event:
    Regards!
