755
can't close the window dialog
I have please the following problem with closing window dialog:
I have this JS function for opening and hiding window dialog:
 function showDialog(id) {
   var igJsDwNode = ig.dw.getDwJsNodeById(id);
   if (igJsDwNode !== null) {
      igJsDwNode._show();
function hideDialog(formName, id) {
   var igJsDwNode = ig.dw.getDwJsNodeById(formName + ':' + id);
      igJsDwNode._hide();
I use this link for opening window dialog:
<h:graphicImage url="images/icon_add_binding.gif" onclick="showDialog('agSearchForm:agPopup');return false;" />
And here is window dialog definition:
    <h:form id="agSearchForm">
      <ig:dialogWindow id="agPopup"
            modal="true"
            windowState="hidden"
            initialPosition="manual"
            style="width:550px; height:500px; left:300px; top:120px;"
            rendered="#{assetController.asset.id > 0}">
        <ig:dwHeader captionText="#{gui['assetGroup.list']}">
          <ig:dwResizer />
          <ig:dwCloseBox />
        </ig:dwHeader>
        <ig:dwContentPane>
          <h:outputText value="#{gui['assetGroup.list']}" styleClass="heading3" />
          <h:commandButton onclick="hideDialog(this.form.name, 'agPopup');return false;" value="#{gui['close']}" />
        </ig:dwContentPane>
      </ig:dialogWindow>
    </h:form>
I'm not able to close dialog with cross but closing with my button works fine.
I use last hotfix (2014) version and MyFaces JSF implementation.
ANECT
  • 2151
    You should avoid invoking JS functions beginning with undescore (_). These functions are "private". You have probably seen this in one of our examples, which is our issue and we will fix it. The right method to invoke for show/hide the DW is:
    dw.set_windowState(ig.dw.STATE_NORMAL);
    dw.set_windowState(ig.dw.STATE_HIDDEN);
    However I just saw that there is a issue when invoking the "set_windowState" so probably you have to request a private hotfix for this issue using the support service.
