360
Check Box in Ultr Web Grid
Hi all
i have a check box in one of Template columns of Ultra Webgrid
when user checks the check box i want to check on CheckChanged event that how much Chec boxes are checked. I have done this thing on Server Side. One problem is that how i can get the check box . Means, Like in Grid View we do some thing like this
foreach (GridViewRow row in GridView1.Rows)
     CheckBox chk  = (CheckBox) row.FindControl("checkBox")  (how i can do this thing in ultra web grid)
     if(chk.Checked)
                    //Do some thing
2nd thing is that is there any other way i can do this thing instead of Going back to Server each time????
  • 28464
    Verified Answer
     Hello Muhammad,
    I believe it is possible to have this scenario. Just remove the postback event on check for each checkbox on the template, set a general "Ok" or "Submit" button below the grid and use the following code to obtain the checked nodes:
    <igtbl:TemplatedColumn Key="CustomerID">
        <CellTemplate>
            <asp:CheckBox runat="server" ID="CheckBox1" />
        </CellTemplate>
    </igtbl:TemplatedColumn>
    protected void Button1_Click(object sender, EventArgs e)
            TemplatedColumn column = (TemplatedColumn) UltraWebGrid1.Columns.FromKey("CustomerID");
            int counter = 0;
            foreach (CellItem item in column.CellItems)
                CheckBox checkBox = (CheckBox) item.FindControl("CheckBox1");
                if (checkBox.Checked)
                    Page.Response.Write("Checkbox on row " + counter.ToString() + " is checked");
                counter = counter + 1;
    Please, let me know if this helps.
