75
Setting ValueList in WebGrid Column Javascript
I am able to set up a two-dimensional array using Javascript and bind it to the ValueList of an UltraWebColumn.  The only thing that goes wrong is that the DisplayStyle seems to get ignored afterward and, even though the drop down displays text, once I select an item, the value member, not the display member, shows up in the cell.  I am using 7.2 for .NET 2.0 - anybody have any ideas?
  • 210
    Make the data type of your dropdown column "System.String"
    and put your javascript data in quotes, all of your data goes in quotes.
    like this...
    var myLocationTypes = [
    ["0", ""],
    ["1", "Marina"],
    ["2", "Terminal"],
    ["3", "Refinery"],
    ["4", "Manufacturing Facility"],
    ["5", "Historical Vessel"],
    ["6", "Wharf"],
    ["7", "Pier"],
    ["8", "Shipyard"]
    use double quotes too, no singles.
