1147
WebTree Client Side Search
  How one can search a tree and highlight the searched Item in a webtree using javascript?
  • 28464
    You can use the client-side object model of the treeview (CSOM) and the getNodes method in particular (getNodes(true) mean recursive search) to obtain all nodes in the tree. Then implementing a FindNodeByText() method, finding a node and selecting it  will look something like this
    <ignav:UltraWebTree ID="UltraWebTree1" runat="server" DefaultImage=""
            HiliteClass="" HoverClass="" Indentation="20">
            <ClientSideEvents NodeClick="nodeClickHandler" />
            <Levels>
                <ignav:Level Index="0" />
            </Levels>
            <Nodes>
                <ignav:Node Text="Root Node">
                    <Nodes>
                        <ignav:Node Text="Child Node">
                        </ignav:Node>
                        </ignav:Node>
                        </ignav:Node>
                    </Nodes>
                </ignav:Node>
                    <Nodes>
                        </ignav:Node>
                        </ignav:Node>
                        <ignav:Node Text="NY">
                        </ignav:Node>
                    </Nodes>
                </ignav:Node>
                    <Nodes>
                        </ignav:Node>
                        </ignav:Node>
                        </ignav:Node>
                    </Nodes>
                </ignav:Node>
            </Nodes>
        </ignav:UltraWebTree>
        <script language="javascript">
            function FindNodeByText(tree, text) {
                var nodes = tree.getNodes(true);
                for (var i = 0; i < nodes.length; i++)
                    if (nodes[i].getText() == text)
                        return nodes[i];
            function selectNY() {
                var tree = igtree_getTreeById("<%= UltraWebTree1.ClientID %>");
                var node = FindNodeByText(tree, "NY");
                if (node != null)
                    tree.setSelectedNode(node);
        </script>
        <input type="button" onclick="selectNY()" id="Button1" value="Select NY" />
    More info on that can be found in the online help located here: (CSOM section)
    http://help.infragistics.com/NetAdvantage/NET/2008.2/CLR2.0/
