360
Need Help in Row Editting
Hi All
i want to some thing similar to that which i have attached with this post. but i am facing following exeption and dont know what to do.
Server Error in '/TempTest' Application.
Databinding methods such as Eval(), XPath(), and Bind() can only be used in the context of a databound control.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: Databinding methods such as Eval(), XPath(), and Bind() can only be used in the context of a databound control.
Source Error:
Line 332:                                                <td style="font-size: 8pt; font-family: Verdana" align="left">
Line 333:                                                    Code:<br>
Line 334:                                                    <asp:TextBox ID="TextBox1" runat="server" Font-Size="8pt" Width="190px" columnKey="Code"
Line 335:                                                        Font-Name="Verdana" Font-Names="Verdana" Text='<%# Eval("Code") %>'></asp:TextBox></td>
Line 336:                                            </tr>
Source File: d:\ideaGate\Projects\AL-Sarraf\Prototype\Main\Bizlogix\Lookups\CurrencyManagement.aspx    Line: 334
Stack Trace:
[InvalidOperationException: Databinding methods such as Eval(), XPath(), and Bind() can only be used in the context of a databound control.]
   System.Web.UI.Page.GetDataItem() +2647882
   System.Web.UI.TemplateControl.Eval(String expression) +31
   ASP.lookups_currencymanagement_aspx.__DataBinding__control42(Object sender, EventArgs e) in d:\ideaGate\Projects\AL-Sarraf\Prototype\Main\Bizlogix\Lookups\CurrencyManagement.aspx:334
   System.Web.UI.Control.OnDataBinding(EventArgs e) +99
   System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
   System.Web.UI.Control.DataBind() +15
   System.Web.UI.Control.DataBindChildren() +211
   System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
   Infragistics.WebUI.UltraWebGrid.DBBinding.BindList(IEnumerable datasource) +760
   Infragistics.WebUI.UltraWebGrid.DBBinding.DataBind(Object dataSource, String dataMember) +950
   Infragistics.WebUI.UltraWebGrid.UltraWebGrid.DataBind() +405
   Lookups_CurrencyManagement.BindGridData() in d:\ideaGate\Projects\AL-Sarraf\Prototype\Main\Bizlogix\Lookups\CurrencyManagement.aspx.cs:99
   Lookups_CurrencyManagement.Page_Load(Object sender, EventArgs e) in d:\ideaGate\Projects\AL-Sarraf\Prototype\Main\Bizlogix\Lookups\CurrencyManagement.aspx.cs:22
   System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
   System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
   System.Web.UI.Control.OnLoad(EventArgs e) +99
   System.Web.UI.Control.LoadRecursive() +50
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3053
 Here is Code Behind:
using System;
using System.Collections;
using System.Configuration;
using System.Data;
using System.Linq;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Xml.Linq;
using Infragistics.WebUI.UltraWebGrid;
public partial class Lookups_CurrencyManagement : System.Web.UI.Page
DataTable tblCurrencies = new DataTable();
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
this.BindGridData();
protected void chkSelect_CheckedChanged(object sender, EventArgs e)
int count = 0;
Control cnt=null;
TemplatedColumn tc = null;
CheckBox radio = null;
tc = (TemplatedColumn) grdEnglishCurrencies.Columns[0];
for (int i = 0; i < grdEnglishCurrencies.Rows.Count; i++)
cnt = (
Control) tc.CellItems[i];
radio = (CheckBox) cnt.FindControl("chkSelect");
if (radio.Checked)
count++;
if (count > 0)
this.btnDeleteAbove.Enabled = true;this.btnDeleteBelow .Enabled = true;
else
this.btnDeleteAbove.Enabled = false;this.btnDeleteBelow .Enabled = false;
private void BindGridData()
//DataTable tblCurrencies = new DataTable();
tblCurrencies.Columns.Add(new DataColumn("ID"));
tblCurrencies.Columns.Add(new DataColumn("Code"));
tblCurrencies.Columns.Add(new DataColumn("Title"));
tblCurrencies.Columns.Add(new DataColumn("Description"));
tblCurrencies.Columns.Add("Sign");
tblCurrencies.Columns.Add("Coin");
tblCurrencies.Columns.Add("LeastDecValue");
tblCurrencies.Columns.Add("CalBasisDays");
tblCurrencies.Columns.Add("ExchRate");
tblCurrencies.Columns.Add("DefCurrency");
DataRow row = tblCurrencies.NewRow();
row["ID"] = 1;
row["Code"] = "code";
row["Title"] = "Title";
row["Description"] = "This is Some Description. I dont know any thisn ";
row["Sign"] = "$";
row["Coin"] = "Cell";
row["LeastDecValue"] = "2";
row["CalBasisDays"] = "4";
row["ExchRate"] = "34";
row["DefCurrency"] = "1";
tblCurrencies.Rows.Add(row);
this.grdEnglishCurrencies.DataSource = tblCurrencies;this.grdEnglishCurrencies.DataBind();
Here is Aspx Page:
<%@ Page Language="C#" MasterPageFile="~/MainMaster.master" AutoEventWireup="true" CodeFile="CurrencyManagement.aspx.cs" Inherits="Lookups_CurrencyManagement" Title="Untitled Page" %>
<%@ Register assembly="Infragistics2.WebUI.UltraWebGrid.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
<%@ Register assembly="Infragistics2.WebUI.UltraWebTab.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebTab" tagprefix="igtab" %> <%@ Register assembly="Infragistics2.WebUI.UltraWebNavigator.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebNavigator" tagprefix="ignav" %>
<%@ Register assembly="Infragistics2.WebUI.Misc.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.Misc" tagprefix="igmisc" %>
<asp:Content ID="Content1" runat="server"
contentplaceholderid="ContentPlaceHolder1">
function TemplateUpdateControls(gn,ctrlId,cellId,value)
if(ctrlId=="MaskEdit1")
igtbl_getElementById(ctrlId).Text=value;
return true;
else if(ctrlId=="PVDate1" || ctrlId=="PVDate2" || ctrlId=="PVDate3")
var d=new Date(value);
igtbl_getElementById(ctrlId).Value=(d.getMonth()+1).toString()+"/"+d.getDate()+"/"+d.getFullYear();
return true;
else if(ctrlId=="shipAddrId")
var s=value;
igtbl_getElementById(ctrlId).innerText=value;
return true;
else if(ctrlId=="tmplShipName")
"tmplName").innerText=value;
function TemplateUpdateCells(gn,ctrlId,cellId)
igtbl_getCellById(cellId).setValue(igtbl_getElementById(ctrlId).TextWithMask);
return true;
igtbl_getCellById(cellId).setValue(igtbl_getElementById(ctrlId).Value);
return true;
var s=igtbl_getElementById(ctrlId).innerText;
igtbl_getCellById(cellId).setValue(s);
return true;
function arto()
</script>
<table style="width: 100%">
<tr>
<td colspan="4">
<asp:Label ID="Label1" runat="server" CssClass="DescTitle"
Text="Currency Management" Font-Bold="True" Font-Size="Small"></asp:Label>
</td>
<td>
&nbsp;</td>
</tr>
<tr>
<td colspan="4">
<asp:ScriptManager ID="ScriptManager1" runat="server">
</asp:ScriptManager>
</td>
<td align="right">
<asp:ImageButton ID="imgBtnPrint" runat="server"
ImageUrl="~/Images/printer.gif" />
</td>
</tr>
<tr>
<td colspan="4">
<asp:UpdatePanel ID="UpdatePanel4" runat="server">
<ContentTemplate>
<asp:Label ID="lblMessage" runat="server" Font-Bold="True" ForeColor="#990000"></asp:Label>
</ContentTemplate>
</asp:UpdatePanel>
</td>
<td align="right">
&nbsp;</td>
</tr>
<tr>
<td>
<asp:Button ID="btnAddNewAbove" runat="server" CssClass="text_in_box"
Text="Add New" />
</td>
<td style="width: 84px" colspan="2">
<asp:UpdatePanel ID="UpdatePanel2" runat="server">
<ContentTemplate>
<asp:Button ID="btnDeleteAbove" runat="server" CssClass="text_in_box"
Text="Delete" Enabled="False" />
</ContentTemplate>
</asp:UpdatePanel>
</td>
<td style="width: 536px">
&nbsp;</td>
<td>
&nbsp;</td>
</tr>
<tr>
<td style="height: 8px;">
</td>
<td style="width: 84px; height: 8px;" colspan="2">
</td>
<td style="width: 536px; height: 8px;">
</td>
<td style="height: 8px">
</td>
</tr>
<tr>
<td colspan="4" style="height: 82px">
<asp:UpdatePanel ID="UpdatePanel1" runat="server">
<ContentTemplate>
<igtab:UltraWebTab ID="UltraWebTab1" runat="server"
Width="80%" ontabclick="UltraWebTab1_TabClick">
<Tabs>
<igtab:Tab Text="English" Tooltip="Enter Data in English Language">
<ContentTemplate>
<igtbl:UltraWebGrid ID="grdEnglishCurrencies" runat="server" Height="200px"
Width="80%" >
<DisplayLayout CompactRendering="False" StationaryMargins="HeaderAndFooter" AllowSortingDefault="Yes"
RowHeightDefault="20px" RowSizingDefault="Free" Version="2.00.5000"
SelectTypeRowDefault="Single" AllowColumnMovingDefault="OnServer" SelectTypeCellDefault="Extended"
BorderCollapseDefault="Separate" AllowColSizingDefault="Free" Name="UltraWebGrid1"
TableLayout="Fixed" CellClickActionDefault="RowSelect" AllowUpdateDefault="Yes"
AutoGenerateColumns="False">
<FrameStyle Width="100%" Cursor="Default" BorderWidth="1px" Font-Size="7pt" Font-Names="Verdana"
BorderStyle="Solid" BackColor="#E0E0E0" Height="338px">
</FrameStyle>
<ClientSideEvents AfterRowTemplateOpenHandler="arto" TemplateUpdateControlsHandler="TemplateUpdateControls"
TemplateUpdateCellsHandler="TemplateUpdateCells"></ClientSideEvents>
<Pager>
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px"
WidthTop="1px" />
</PagerStyle>
</Pager>
<EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
</EditCellStyleDefault>
<FooterStyleDefault BorderWidth="1px" BorderStyle="Solid" BackColor="LightGray">
<BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails>
</FooterStyleDefault>
<HeaderStyleDefault VerticalAlign="Middle" BorderWidth="1px" BorderStyle="Solid"
HorizontalAlign="Left" BackColor="LightGray" Height="20px">
<Padding Left="3px" Right="3px"></Padding>
<BorderDetails ColorTop="White" WidthLeft="1px" ColorBottom="Gray" WidthTop="1px"
ColorRight="Gray" ColorLeft="White"></BorderDetails>
</HeaderStyleDefault>
<RowSelectorStyleDefault Width="16px" BorderStyle="Solid" BackColor="White">
<BorderDetails WidthLeft="0px" ColorBottom="224, 224, 224" WidthTop="0px" WidthRight="0px"
WidthBottom="1px"></BorderDetails>
</RowSelectorStyleDefault>
<RowStyleDefault TextOverflow="Ellipsis" VerticalAlign="Middle" BorderWidth="1px"
Font-Size="8pt" Font-Names="Verdana" BorderColor="LightGray" BorderStyle="Solid"
HorizontalAlign="Left" ForeColor="Black" BackColor="White">
<Padding Left="5px"></Padding>
<BorderDetails ColorTop="DimGray" WidthLeft="0px" WidthTop="0px" ColorLeft="DimGray">
</BorderDetails>
</RowStyleDefault>
<GroupByRowStyleDefault BackColor="Control" BorderColor="Window">
</GroupByRowStyleDefault>
<SelectedRowStyleDefault ForeColor="Black" BackColor="LightSteelBlue">
</SelectedRowStyleDefault>
<GroupByBox Hidden="True">
<BoxStyle BackColor="ActiveBorder" BorderColor="Window">
</BoxStyle>
</GroupByBox>
<AddNewBox>
<BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
BorderWidth="1px">
WidthTop="1px" />
</BoxStyle>
</AddNewBox>
<ActivationObject BorderStyle="None" BorderWidth="0px" AllowActivation="False">
</ActivationObject>
<FilterOptionsDefault>
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
BorderWidth="1px" CustomRules="overflow:auto;"
Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Height="300px"
Width="200px">
<Padding Left="2px" />
</FilterDropDownStyle>
<FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
</FilterHighlightRowStyle>
<FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;"
Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px">
</FilterOperandDropDownStyle>
</FilterOptionsDefault>
</DisplayLayout>
<Bands>
<igtbl:UltraGridBand>
<Columns>
<igtbl:UltraGridColumn BaseColumnName="ID" Hidden="True">
<Header Caption="ID">
</Header>
</igtbl:UltraGridColumn>
<igtbl:TemplatedColumn Width="5%">
<CellTemplate>
<asp:CheckBox ID="chkSelect" runat="server"
oncheckedchanged="chkSelect_CheckedChanged" AutoPostBack="True" />
</CellTemplate>
<Header Caption="Select">
<RowLayoutColumnInfo OriginX="1" />
</Header>
<Footer>
</Footer>
</igtbl:TemplatedColumn>
<igtbl:UltraGridColumn AllowUpdate="Yes" BaseColumnName="Code" Width="5%">
<Header Caption="Title">
<RowLayoutColumnInfo OriginX="3" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn AllowUpdate="Yes" BaseColumnName="Title" Width="10%">
<Header Caption="Code">
<RowLayoutColumnInfo OriginX="2" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn Width="25%" AllowUpdate="Yes"
BaseColumnName="Description" CellMultiline="Yes">
<Header Caption="Description">
<RowLayoutColumnInfo OriginX="6" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn AllowUpdate="Yes" BaseColumnName="Sign" Width="5%">
<Header Caption="Sign">
<RowLayoutColumnInfo OriginX="7" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn AllowUpdate="Yes" BaseColumnName="Coin"
CellMultiline="Yes" Width="5%">
<Header Caption="Coin">
<RowLayoutColumnInfo OriginX="4" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn Width="12%" AllowUpdate="Yes"
BaseColumnName="LeastDecValue">
<Header Caption="Least decimal Val">
<RowLayoutColumnInfo OriginX="5" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn AllowUpdate="Yes" BaseColumnName="CalBasisDays"
Width="12%">
<Header Caption="Calc. Basis Days">
<RowLayoutColumnInfo OriginX="9" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn Width="10%" AllowUpdate="Yes" BaseColumnName="ExchRate">
<Header Caption="Exch. Rate">
<RowLayoutColumnInfo OriginX="8" />
</Header>
<Footer>
</Footer>
<igtbl:TemplatedColumn BaseColumnName="DefCurrency" Format="#########"
Width="15%">
<CellTemplate>
<asp:CheckBox ID="chkDefaultCurrency" runat="server" AutoPostBack="True"
Enabled="False" oncheckedchanged="chkDefaultCurrency_CheckedChanged" />
</CellTemplate>
<Header Caption="Default Currency">
<RowLayoutColumnInfo OriginX="10" />
</Header>
<Footer>
</Footer>
</Columns>
<RowEditTemplate>
<div style="padding: 2px; font-size: 8pt; width: 65%; font-family: Verdana; height: 35px; background-color: cornsilk">
Details For Currency:
<div id="tmplName" style="font-weight: bold">
Name</div>
</div>
<table cellspacing="5" cellpadding="0" border="0" style="width: 100%">
<tr>
<td valign="top" bgcolor="white" style="border-right: #000000 1px solid; border-top: #000000 1px solid;
border-left: #000000 1px solid; border-bottom: #000000 1px solid">
<table cellspacing="5" cellpadding="0" width="100%" border="0">
<tbody>
<tr>
</td>
</td>
</tr>
<tr>
Code:<br>
</tr>
<tr>
title:<br>
<asp:TextBox ID="TextBox2" runat="server" Font-Size="8pt" Width="190px" columnKey="Title"
Font-Name="Verdana" Font-Names="Verdana" Text='<%# Eval("Title") %>'></asp:TextBox></td>
</tr>
<tr>
Sign:<br>
<asp:TextBox ID="TextBox3" runat="server" Font-Size="8pt" Width="190px" columnKey="Sign"
Font-Name="Verdana" Font-Names="Verdana" Text='<%# Eval("Sign") %>'></asp:TextBox></td>
</tr>
</table>
<td bgcolor="white" style="border-right: #000000 1px solid; border-top: #000000 1px solid;
<table cellspacing="5" cellpadding="0" border="0">
<tr>
<td style="font-size: 8pt; font-family: Verdana" align="right">
Coin:</td>
<td>
<asp:TextBox ID="TextBox4" runat="server" Font-Size="8pt"
Text='<%# Eval("Coin") %>'></asp:TextBox>
&nbsp;</td>
</tr>
<tr>
<td style="font-size: 8pt; font-family: Verdana" valign="top" align="right">
Description:</td>
<td>
<asp:TextBox ID="TextBox5" runat="server" Text='<%# Eval("Description") %>'
TextMode="MultiLine"></asp:TextBox>
&nbsp;</td>
</tr>
<tr>
Ship City:</td>
<td>
<input style="font-size: 8pt; width: 125px; font-family: Verdana" type="text" size="22"
columnkey="ShipCity">
</td>
</tr>
<tr>
Ship region:</td>
<td>
<input style="font-size: 8pt; width: 125px; font-family: Verdana" type="text" size="10"
columnkey="ShipRegion">
</td>
</tr>
<tr>
Ship Postal Code:</td>
<td>
columnkey="ShipPostalCode">
</td>
</tr>
<tr>
Ship Country:</td>
<td>
columnkey="ShipCountry">
</td>
</tr>
</table>
</td>
<caption>
<br>
<input ID="igtbl_reOkBtn" onclick="igtbl_gRowEditButtonClick(event);" style="font-size: 8pt; width: 75px; font-family: Verdana;
background-color: lightsteelblue" type="button" value="OK">&nbsp;&nbsp;
<input ID="igtbl_reCancelBtn" onclick="igtbl_gRowEditButtonClick(event);" style="font-size: 8pt; width: 75px; font-family: Verdana;
background-color: darkseagreen" type="button" value="Cancel">
</caption>
</RowEditTemplate>
<RowTemplateStyle BackColor="Window" BorderColor="Window" BorderStyle="Ridge">
<BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px"
WidthTop="3px" />
</RowTemplateStyle>
<AddNewRow View="NotSet" Visible="NotSet">
</AddNewRow>
</igtbl:UltraGridBand>
</Bands>
</igtbl:UltraWebGrid>
</ContentTemplate>
</igtab:Tab>
<igtab:Tab Text="Arabic" Tooltip="Enter Data in Arabic Language">
<ContentTemplate>
<igtbl:UltraWebGrid ID="grdArabicCurrencies" runat="server" Height="200px"
Width="325px">
<bands>
<addnewrow view="NotSet" visible="NotSet">
</addnewrow>
</bands>
<displaylayout allowcolsizingdefault="Free" allowcolumnmovingdefault="OnServer"
allowdeletedefault="Yes" allowsortingdefault="OnClient"
allowupdatedefault="Yes" bordercollapsedefault="Separate"
headerclickactiondefault="SortMulti" name="UltraWebGrid1"
rowheightdefault="20px" rowselectorsdefault="No"
selecttyperowdefault="Extended" stationarymargins="Header"
stationarymarginsoutlookgroupby="True" tablelayout="Fixed" version="4.00"
viewtype="OutlookGroupBy">
<framestyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid" borderwidth="1px" font-names="Microsoft Sans Serif"
font-size="8.25pt" height="200px" width="325px">
</framestyle>
<pager minimumpagesfordisplay="2">
<borderdetails colorleft="White" colortop="White" widthleft="1px"
widthtop="1px" />
</PagerStyle>
</pager>
<editcellstyledefault borderstyle="None" borderwidth="0px">
</editcellstyledefault>
<footerstyledefault backcolor="LightGray" borderstyle="Solid" borderwidth="1px">
widthtop="1px" />
</footerstyledefault>
<headerstyledefault backcolor="LightGray" borderstyle="Solid"
horizontalalign="Left">
widthtop="1px" />
</headerstyledefault>
<rowstyledefault backcolor="Window" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" font-names="Microsoft Sans Serif" font-size="8.25pt">
<padding left="3px" />
<borderdetails colorleft="Window" colortop="Window" />
</rowstyledefault>
<groupbyrowstyledefault backcolor="Control" bordercolor="Window">
</groupbyrowstyledefault>
<groupbybox>
<boxstyle backcolor="ActiveBorder" bordercolor="Window">
</boxstyle>
</groupbybox>
<addnewbox hidden="False">
<boxstyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid"
borderwidth="1px">
widthtop="1px" />
</boxstyle>
</addnewbox>
<activationobject bordercolor="" borderwidth="">
</activationobject>
<filteroptionsdefault>
<filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px" height="300px"
width="200px">
<padding left="2px" />
</filterdropdownstyle>
<filterhighlightrowstyle backcolor="#151C55" forecolor="White">
</filterhighlightrowstyle>
<filteroperanddropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px">
</filteroperanddropdownstyle>
</filteroptionsdefault>
</displaylayout>
</ContentTemplate>
</igtab:Tab>
</Tabs>
</igtab:UltraWebTab>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="btnAddNewAbove" EventName="Click" />
<asp:AsyncPostBackTrigger ControlID="btnDeleteAbove" EventName="Click" />
<asp:AsyncPostBackTrigger ControlID="btnAddNewBelow" />
<asp:AsyncPostBackTrigger ControlID="btnDeleteBelow" />
</Triggers>
</asp:UpdatePanel>
</td>
<td style="height: 82px">
</td>
</tr>
<tr>
<td colspan="4" style="height: 30px">
</td>
<td style="height: 30px">
</td>
</tr>
<tr>
<td>
<asp:Button ID="btnAddNewBelow" runat="server" CssClass="text_in_box"
Text="Add New" />
</td>
<td>
<asp:UpdatePanel ID="UpdatePanel3" runat="server">
<ContentTemplate>
<asp:Button ID="btnDeleteBelow" runat="server" CssClass="text_in_box"
</ContentTemplate>
</asp:UpdatePanel>
</td>
<td colspan="2">
&nbsp;</td>
<td>
&nbsp;</td>
</tr>
</table> </asp:Content>
