Does anyone know if its possible add a Server Control ImageButton to a tab's little header portion?
J
Tab labels do not support templates, however, you may set their Text which "contains" templates. For example, you may insert a button by something like
<Tabs> <igtab:Tab Text="New Tab <input type='button' value='but' onclick='myClick()' />"></igtab:Tab> ...</Tabs>
function myClick(){ var tb = document.getElementById('TextBox1'); if(tb) tb += 'x'; //tb.value = 'postback by tab'; __doPostBack('TextBox1');}
So, now on server you at least will get postback. If you have somewhere on page TextBox1 and you process its TextChange event, then that handler also should be hit.
Note: if you do similar, then there is no support in case of misbehavior or any side efffects.
