85
NoClassDefFoundError: PortletResponse
 hello dear community,
 i have the following problem:
i made a class, which reads an xml, writes the elements in new objects with getter and setter.
this  class works as my datasource in my grid.it works good.
when i edit a field in my grid i get the following message two times:
 E   SRVE0026E: [Servlet-Fehler]-[Faces Servlet]: java.lang.NoClassDefFoundError: javax.portlet.PortletResponse
have someone an idea, what this is?
  • 28464
    Are you using the JSF suite? From the error message I can tell that the platform is Java, while here is the ASP.NET forums. If you are using our Java JSF package, you can visit the JSF grid forum located here:
    http://forums.infragistics.com/forums/161.aspx
    and ask the question there.
    Hope this helps.
