hello dear community,
i have the following problem:
i made a class, which reads an xml, writes the elements in new objects with getter and setter.this class works as my datasource in my grid.it works good.when i edit a field in my grid i get the following message two times:
E SRVE0026E: [Servlet-Fehler]-[Faces Servlet]: java.lang.NoClassDefFoundError: javax.portlet.PortletResponse
i downloaded portlet-api.jar ad put it in my web-libs folder, now it works ok.
Hi, maikvogel!
It would be great if you could provide me some more information on this issue, i.g. post a code snippet so that I can reproduce this case on my machine. Thank you in advance for your feedback.
Regards!
