Hi friends:
How can I cancel the Event (ondemandload="UltraWebTree1_DemandLoad" that is in server site) in javascript funcion ""demandLoad(treeID, nodeID)"(treeID, nodeID)" .
If the "demandLoad(treeID, nodeID)"function has the property like " oEvent.Cancel = true ".
If someone Know the answer, please tell me,
Thank you very much!
Thank you. it works :)
Cancelling a client-side in UltraWebTree is a little bit counter intuitive indeed - you typically cancel an event by returning true from the event handler. You can take a look at the list of client events for UltraWebTree here:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/WebTree_Client_Side_Events_CSOM.html
and take a look at the text at the top:
<quote>
Note: Most of these client-side events are cancelable. The most significant of which are the Before events. To cancel an event, return true in the event handler. For cases in which a Before event has a corresponding server-side event handled, returning true in the client-side event also cancels the postback to trigger the server-side event.
</quote>
Event though DemandLoad does not start with Before... I have just taken a look at our source code and verified that returning true from the DemandLoad client side event handler will indeed cancel the server event.
