In my application there is WebGrid. I have added client side event on cellclick that programmatically selects row wchich clicked cell belongs to.It just invokes the setSelectes() method on active row. The problem is that i would like to keep the functionality of copying clicked cell value into clipboard even if clicking on the cell makes whole row selected. After adding this event whole row selects, which is fine, but values from all cells in that row copies into clipboard. The DisplayLayout CellClickActionDefault is set to CellSelect.
powersystem
I'm not sure you're on the right place, so could you please specify which version of NetAdvantage you're using.
Thank you in advance for your feedback.
Regards!
