320
Not Set value on cell for BeforeEnterEditModeHandler.
Hello
I have facing on issue.
i am using ultrawebgrid which have datetime column.
my problem is when cell in edit mode cell value display Date in this format "Mon Jan 1 00:00:00 UTC+0530 1900" and cell display mode value "1/1/1900" so my problem is when cell in edit mode value should be dispaly in "1/1/1900" this format.
so i have use one Javascript on Grid_BeforeEnterEditModeHandler.
var cell = igtbl_getCellById(cellId);var date=cell.getValue().format("MM/dd/yyyy");
then alert(date); return value as per my requirement "1/1/1900".
But when i try to set value in edit mode it is not set in cell when i using below code.
cell.setValue(date.toString());
so any other way to solve above issue i want same value in edit as well as in display mode. like "1/1/1900"?
Please provide solution as soon as possible.
Thanks in Advance.
