1360
Formatting Issues with WebGrid (1) - Column Widths
If I attempt to set the width of individual columns in a web grid to anything other than percentages the width property is ignored. Surely this major glitch cannot be a bug in a product of this vintage! How long has this product been on sale?
What I need to do is similar to the table layouts declared in html whereby one or more columns have their width explicitly stated in pixels and the remaining column has a width of "100%" indicating that it should occupy, fully, whatever space is left.
Is it possible to do this?
VS2008 Pro, IG2008v1, C#
Kind regards
Paul
  • 8680
    I'm not sure what's supposed to happen when you mix pixels with percentages, but I've had no problem setting widths to pixels.
    If you leave out the last "100%", do the pixel values work correctly?
    If not, you might want to post your markup and any code that sets widths.
  • 3338
    Don't know how much help this will be.
    There is a property whereby you can set the last column to expand to the width of the grid.
    see if this post helps.
    http://forums.infragistics.com/forums/p/6421/40957.aspx#40957
