525
How to add template column at ultrwebgrid second band
Hi
Iam using Ultrawebgrid(version 8.2) in my grid i had 3 bands i want to add link button as template column at second band, in my seconf\d band i had 10 columns all are bound columns and if i add 11th column as template column which contains a linkbutton, at runtime in second band it is showing only this column other columns are not coming.
At my display layout i had given Autogeneratecolumns ="false"  how to add template column at sencond band with out effecting other columns
Sivaprasad
  • 8680
    Based on your description, I can't tell why it isn't working.  If you set AutoGenerateColumns = false, any bound columns you define in your markup should display.  I can't promise anything, but if you post your markup (and any code that manipulates the grid), I'll take a look at it.
