I am currently evalulating the UltraWebGrid for my company and I have run into a problem that should be easy (I hope). I have added the grid to my asp.net form and I want to reference it in javascript in order to handle the resize. I read several posts here on how to do this and specifically in the help it mentions to get a reference you do this:
var grid = igtbl_getGridById("UltraWebGrid1");
However, when I hit this line of code, I get the "Object expected" error. It seems as if the javascript containing this function is not getting imported somehow. However, it seems to work when I run the samples browser, so there must be something I am missing in my application.
Is there something in web.config or declarations section that I need that is not mentioned in the help or in the samples browser?
Tom
You can either open the HTML source of the page and look for the <script src=> tags, or attach a debugger to the browser (firebug, iedevtoolbar in IE8) and see which scripts are currently loaded.
If the script tags are present, but the scripts are not present in the browser's memory that might give you an idea why.
WHat do you mean by referenced? How can I add this references? I thought that these references would be aded automatically.
Thanks, Alex
Are all of the javascript files referenced correctly? If igtbl_getGridById is unavailable, that usually means something went wrong with the JS files references.
Hello. I have the same problem: I get the object expected error in my Javascript method when calling this method - var theGrid = igtbl_getGridById("<%=ugCoverageHistory.ClientID %>");. My grid is on a content page included in a master page. Any ideas?
Alex
yep, you guessed it - it was on a panel that is hidden when the page first loads. I'm currently moving forward with implementing my grid on a new page, so far so good.
Thanks for the replies.
