220
Copy of webgrid row with checkbox column not working
Hi, I've edited my original message to make it easier to read and updated it to my current situation so please ignore my 2 subsequent posts.
I've added a checkbox column with select all checkbox header to my webgrid as per this forum post http://forums.labs.infragistics.com/forums/p/1156/11700.aspx#11700
A copy and paste method which moves the selected rows to another grid is now exhibiting very strange behaviour.
Initially when I did grid.copy() after using the select all checkbox to select all the rows the copy was failing. If I checked all the rows manually it worked fine.  I resolved this issue by adding a line to activate the row before selecting it and copying it.
Now if I just use the select all button and then copy it all works fine.
However if I first manually check and copy the first row (which works fine), then use select all and copy to copy the rest of the rows the first row of the rest of the rows doesn't get copied correctly and only the checkbox value gets copied but all the subsequent rows copy correctly.
Similarly, if I've only got 2 rows in the grid and I manually copy the last row then the checkbox value only will be copied for the first row if I use the select all and copy. However if there are more than 2 rows and I copy the last row first, then select all and copy the rest they all copy correctly.
Any suggestions or help would be much appreciated.
Colette
