Currently I use the Infragistics.WebUI.UltraWebGrid in my web application. I develop my application in VS 2008 and .net Framework 2.0.50727. I used the ultrawebgrid and bind it to sqlDataSource. I also set allow paging for ultrawebgrid. When I retrieved 20000 records, it will takes me about 3 minutes or sometimes it does not come out any results ( look like still running). But when I retrieved 150 records, it will takes me about 5 seconds. I am wondering that whether ultraWebgrid has the performance issue. When I replace ultrawebgrid with gridview, When I retrieved 20000 records, it only takes 5 seconds. Because I will use the pretty user interface from ultrawebgrid, I hope anybody can help me solve the problem or does anyone have the same problem before. By the way, I have another issue, why ultrawebgrid everytime need to rebind again but gridview we don't need to bind again, how can we get the records from ultrawebgrid without rebinding for postback.
I put my test source code as follows:
In Web.config, you can set up
<connectionStrings> <add name="results_developmentConnectionString2" connectionString="Data Source=Server Name;Initial Catalog=Database Name;Persist Security Info=True;User ID=XXXX;Password=XXXX"/> </connectionStrings>
in GridTest.aspx.vb
Partial Class GridTest Inherits System.Web.UI.Page Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load SqlDMC_Main.ConnectionString = ConfigurationManager.ConnectionStrings("results_developmentConnectionString2").ToString() UltraWebGridDMC_Main.DataBind() End SubEnd Class
In GridTest. aspx
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="GridTest.aspx.vb" Inherits="GridTest" %>
<%@ Register assembly="Infragistics2.WebUI.UltraWebGrid.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title></head><body> <form id="form1" runat="server"> <div> <igtbl:UltraWebGrid ID="UltraWebGridDMC_Main" runat="server" DataSourceID="SqlDMC_Main" DataKeyField="ActivityID"> <bands> <igtbl:UltraGridBand DataKeyField="ActivityID"> <Columns> <igtbl:TemplatedColumn AllowResize="Free" Width="30px" SortIndicator="Disabled"> <CellTemplate> <asp:ImageButton ID="btnSelect" CommandArgument="Select" CommandName="cmdSelectDetail" runat="server" ImageUrl="~/IMAGES/list.gif" /> </CellTemplate> <CellStyle Width="30px" wrap="false"></CellStyle> </igtbl:TemplatedColumn> <igtbl:TemplatedColumn Key="Completed" BaseColumnName="Completed" Hidden="false" AllowResize="Free" Width="30px" DataType="System.String" > <CellTemplate> <asp:CheckBox ID="ChkCompleted" runat="server" Enabled="false" Checked='<%# iif(Eval("Completed").ToString()="Y",true,false) %>' /> </CellTemplate> <CellStyle width="10px" Wrap="false"></CellStyle> <Header Caption="Completed"> <RowLayoutColumnInfo OriginX="1"> </RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo> </Footer> </igtbl:TemplatedColumn> <igtbl:TemplatedColumn Key="ActivityID" BaseColumnName="ActivityID" Hidden="false" AllowResize="Free" Width="40px" DataType="System.Int32" > <CellTemplate> <asp:LinkButton ID="lbEdit" CommandArgument="Edit" CommandName="cmdEditDetail" runat="server" Text='<%#Eval("ActivityID")%>'> </asp:LinkButton> </CellTemplate> <CellStyle width="10px" Wrap="false"></CellStyle> <Header Caption="ID"> <RowLayoutColumnInfo OriginX="1"> </RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo> </Footer> </igtbl:TemplatedColumn> <igtbl:UltraGridColumn BaseColumnName="ActivityID" DataType="System.Int32" IsBound="True" Key="ActivityID" Hidden="true"> <Header Caption="Activity ID" > <RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="ActivityType" DataType="System.String" IsBound="True" Key="ActivityType" AllowResize="Free" Width="100px"> <Header Caption="Activity Type"> <RowLayoutColumnInfo OriginX="3"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="3"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Priority" IsBound="True" DataType="System.String" Key="Priority" AllowResize="Free" Width="20px"> <Header Caption="Priority" > <RowLayoutColumnInfo OriginX="4"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="4"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="StartDate" Key="StartDate" IsBound="True" AllowResize="Free" DataType="System.DateTime" Format="d" Width="80px" Hidden="true"> <Header Caption="Start Date"> <RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="StartDateTime" Key="StartDateTime" IsBound="True" AllowResize="Free" DataType="System.DateTime" Format="g" HTMLEncodeContent="false" width="120px" SortIndicator="Descending" > <Header Caption="Start Date Time"> <RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="StartTime" Key="StartTime" IsBound="True" Width="120px" Hidden="true" DataType="System.String" AllowResize="Free"> <Header Caption="Time"> <RowLayoutColumnInfo OriginX="7"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="7"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="TotalHours" Key="TotalHours" IsBound="True" DataType="System.Decimal" Format="F2" Width="45px" AllowResize="Free"> <Header Caption="Hours"> <RowLayoutColumnInfo OriginX="6"></RowLayoutColumnInfo> </Header> <Footer> <RowLayoutColumnInfo OriginX="6"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Description" Key="Description" IsBound="True" Width="250px" DataType="System.String" AllowResize="Free"> <Header Caption="Description"> <RowLayoutColumnInfo OriginX="8"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="8"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="ContactID" Key="ContactID" IsBound="True" Width="75px" Hidden="true" DataType="System.Int32" AllowResize="Free"> <Header Caption="Contact ID"> <RowLayoutColumnInfo OriginX="9"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="9"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="DisplayName" Key="DisplayName" IsBound="True" Width="200px" DataType="System.String" AllowResize="Free"> <Header Caption="Contact Display Name"> <RowLayoutColumnInfo OriginX="10"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="10"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="AssociateID" Key="AssociateID" IsBound="True" Width="75px" Hidden="true" DataType="System.Int32" AllowResize="Free"> <Header Caption="Associate ID"> <RowLayoutColumnInfo OriginX="12"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="12"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="DisplayName1" Key="DisplayName1" IsBound="True" Width="250px" Hidden="true" DataType="System.String" AllowResize="Free"> <Header Caption="Associate Display Name"> <RowLayoutColumnInfo OriginX="11"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="11"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="ProjectCode" Key="ProjectCode" IsBound="True" Width="130px" DataType="System.String" AllowResize="Free"> <Header Caption="Proj./Opp. Code"> <RowLayoutColumnInfo OriginX="13"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="13"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="BillableActivity" Key="BillableActivity" IsBound="True" Width="53px" Hidden="true" DataType="System.String" AllowResize="Free"> <Header Caption="Billable"> <RowLayoutColumnInfo OriginX="14"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="14"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="BillQuantity" Key="BillQuantity" IsBound="True" Width="60px" Hidden="true" DataType="System.Decimal" AllowResize="Free"> <Header Caption="Bill Hours"> <RowLayoutColumnInfo OriginX="15"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="15"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="UpdatedOn" Key="UpdatedOn" HTMLEncodeContent="false" DataType="System.DateTime" Format="g" IsBound="True" Width="120px" AllowResize="Free"> <Header Caption="Updated On"> <RowLayoutColumnInfo OriginX="23"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="23"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Updatedby" Key="Updatedby" HTMLEncodeContent="false" IsBound="True" Hidden="true" DataType="System.String" AllowResize="Free"> <Header Caption="Updated By"> <RowLayoutColumnInfo OriginX="22"></RowLayoutColumnInfo> </Header> <CellStyle Width="200px" Wrap="false"></CellStyle> <Footer> <RowLayoutColumnInfo OriginX="22"></RowLayoutColumnInfo> </Footer> </igtbl:UltraGridColumn> </Columns> <RowTemplateStyle BackColor="Window" BorderColor="Window" BorderStyle="Ridge"> <BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px" WidthTop="3px" /> </RowTemplateStyle> <addnewrow view="NotSet" visible="NotSet"> </addnewrow> </igtbl:UltraGridBand> </bands> <displaylayout allowsortingdefault="Yes" headerclickactiondefault="SortMulti" name="UltraWebGrid1" stationarymarginsoutlookgroupby="True" version="4.00" RowSelectorsDefault="No" SelectTypeRowDefault="Single" TableLayout="Fixed" BorderCollapseDefault="Separate"> <FrameStyle BorderStyle="None" BorderWidth="3px" BorderColor="#999999" Cursor="Default"> </FrameStyle> <RowAlternateStyleDefault BackColor="#E9E9F7" Font-Names="Arial"> <BorderDetails ColorLeft="233, 233, 247" ColorTop="233, 233, 247" /> </RowAlternateStyleDefault> <Pager AllowPaging="True" Alignment="Left"> <PagerStyle Font-Size="9pt" /> </Pager> <HeaderStyleDefault BackColor="#2B64A7" BorderStyle="Solid" BorderColor="Black" ForeColor="White" Font-Size="10pt" Font-Names="Arial"> <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" /> </HeaderStyleDefault> <RowStyleDefault BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px" BackColor="White" Font-Size="10pt"> <Padding Left="3px" /> <BorderDetails ColorLeft="199, 213, 232" ColorTop="199, 213, 232" /> </RowStyleDefault> <SelectedRowStyleDefault BackColor="#0A75F0" ForeColor="White"> </SelectedRowStyleDefault> <activationobject bordercolor="Black" borderwidth="" BorderStyle="Dotted"> </activationobject> <filteroptionsdefault> <filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px" width="200px"> <padding left="2px" /> </filterdropdownstyle> <filterhighlightrowstyle backcolor="#151C55" forecolor="White"> </filterhighlightrowstyle> <filteroperanddropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px"> <padding left="2px" /> </filteroperanddropdownstyle> </filteroptionsdefault> </displaylayout> </igtbl:UltraWebGrid> </div> <asp:SqlDataSource ID="SqlDMC_Main" runat="server" SelectCommand="SELECT distinct Results_Activities.Completed, Results_Activities.AssignedTo, Results_Activities.ActivityID, Results_Activities.ActivityType, Results_Activities.Priority, Results_Activities.StartDate, Results_Activities.StartTime, Results_Activities.DurationTotal/60 as TotalHours, Results_Activities.Description, Results_Activities.ContactID, Results_Contacts.DisplayName, Results_Activities.AssociateID, Results_ContactAssociates.DisplayName, Results_Activities.CategoryCode as ProjectCode, Results_Activities.BillableActivity, Results_Activities.BillQuantity, results_Activities.UpdatedOn, results_Activities.Updatedby, Results_Activities.StartDateTime FROM Results_Activities LEFT JOIN Results_Contacts ON Results_Activities.ContactID = Results_Contacts.ContactID LEFT JOIN Results_ContactAssociates ON Results_Activities.AssociateID = Results_ContactAssociates.AssociateID LEFT JOIN Lookup_ActivityTypes ON Results_Activities.ActivityType = Lookup_ActivityTypes.Code WHERE ((NOT (Results_Activities.Private = 'Y')) AND (Results_Activities.ContactID IS Null OR Results_Activities.ContactID = 0 OR EXISTS (SELECT Results_Contacts.ContactID FROM Results_Contacts WHERE Results_Contacts.ContactID = Results_Activities.ContactID AND (NOT (Results_Contacts.Private = 'Y')))))"> </asp:SqlDataSource> </div> </form></body></html>
I found that the solution from the following Forum Article helped me...
https://ko.infragistics.com/community/forums/f/retired-products-and-controls/26825/performance-issue---ultrawebgrid-ie8
There is a section in the documentation dedicated to the performance of UltraWebGrid
Live samples https://ko.infragistics.com/samples/aspnet/data-grid/configuring-virtual-scrolling = > AJAX Enabled => WebGrid => Optimize performance
Thanks.
thanks for the suggestion i was having the exact same issue the original poster was having, this really sped up my databinding if 16K + rows.
however, the issue i am having now, is the frame height is rendering for the full dataset instead of just the displayed rows, any suggestions?
It does not work after I set up my grid like what you said.
My standard grid settings are:
DisplayLayout AllowColSizingDefault:FreeAllowColumnMovingDefault:OnServerAllowSortingDefault:OnClient (You might want to try OnServer)HeaderClickActionDefault:SortSingleLoadOnDemand:XMLRowsRange:50 (How Many Rows The Grid Shows At A Time)SeletTypeCellDefault:SingleSelectTypeRowDefault:SingleSortingAlgorithmDefault:BubbleSortStationaryMargins:HeaderTableLayout:FixedUseFixedHeaders:TrueXMLLoadOnDemand:Virtual
Behavior:Browser:XML
When I used this method, I was able to turn off paging because of the XmlLoadOnDemand. I played around with some of the different options to get to this configuration. Just ran a quick test and using this setup, my dataset I am returning has 11k rows. This loads and shows the first set of rows in around 2-3 seconds. Since I am also working with a large amount of data, I use a filter row to minimize database hits. Hope this helps.
