715
AfterCellUpdateHandler
Hi All, In my aspx page, within AfterCellUpdateHandler i want to access DataSet or want to access the DB, is this possible, if not means how can achieve this, or suggest me any other solution. please reply me. Thanks & Regards, Vasanth.
  • 45049
    Unless you want to write your own custom AJAX code, you can't access the DataSet, the database, or any other server-side resources in this client-side event handler.
    If you can perform this functionality on the server instead, consider using either the UpdateCell or UpdateCellBatch server-side events.
