1763
WebGrid's AfterCellUpdate event not beign fired for WebCombo
I have a WebCombo as EditorControl for a column in my WebGrid. When I choose an item from theWebCombo to change the actual value for the cell theAfterCellUpdate (JavaScript) function is fired.. as long as I don't choose the item with ID = 0. I can choose any other item (as many times as I want) and everything works fine, but as soon as I choose the item with ID = 0, the event is fired that time but it won't fire again no matter what I choose.
SInce I already had a "omg, that was it! It was so simple and I didn't see it!" moment [http://forums.infragistics.com/forums/t/14206.aspx] I'm checking if the above described behavior could be caused by some misconfiguration or something like that.
Thanks for your replies.
