I am working to convert a Window based application to a Web Application having almost the same performance. I am using UltraWebGrid to display huge data(almost 400 rows and 80 columns) and doin lots of clientside validations and functionalities. But the perfomance is really bad.
Can you suggest me some ways to increase the performance?
Akshay
Hello Manik,
Well it really depends on your scenario. Unfortunately grids are complex controls that typicaly deal with huge amount of data, so it is not always possible to have ultra fast response in all cases. If you share some details about your setup, maybe we can advise further (maybe we can have some ohter ideas in addition to what I have already posted in the forum link suggested above).
Same goes for application scenarios - which is best for what - it really depends.
We do have a lot of samples and even sample applications (Web Showcase) available here:
http://samples.infragistics.com/2008.2/
Which show how to use the grid in various real-world scenarios.
HTH,
Hi Rumen,
One more issue. Do we have some kind of document which depicts the best practices to use the Ultrawebgrid, which can help in leveraging the Ultrawebgrid well.
Thanks and Regards,
Manik Mittal
I too am facing the performance issue. I have followed the steps mentioned in the link you have mentioned, but still it is eating up a lot of processor and the memory. Can you please help?
Hello Akshay,
You can also check out this thread on performance - some great ideas are shared there:
http://forums.infragistics.com/forums/t/14306.aspx
See the help for topics on performance:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/WebGrid_Performance.html
