the copy functionality on the client side receives an exception in Firefox the exception is:
Error: A script from "http://localhost:3803" was denied UniversalXPConnect privileges.
Any help would be appreciated.
Justin
I think, especially for FireFox, clipboard operations are not something that the UltraWebGrid can control internally. FireFox is very strict when it comes to permissions and especially clipboard operations.
Still, there are some venues you can try. I think the following thread is especially useful:
http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_21269346.html
[scroll down a lot after the Ads to see the response]
and especially the generic copy function here:
function copy_clip(maintext){ if (window.clipboardData) { // the IE-manier window.clipboardData.setData("Text", maintext); } else if (window.netscape) { netscape.security.PrivilegeManager.enablePrivilege('UniversalXPConnect'); var clip = Components.classes['@mozilla.org/widget/clipboard;1'].createInstance(Components.interfaces.nsIClipboard); if (!clip) return; var trans = Components.classes['@mozilla.org/widget/transferable;1'].createInstance(Components.interfaces.nsITransferable); if (!trans) return; trans.addDataFlavor('text/unicode'); var str = new Object(); var len = new Object(); var str = Components.classes["@mozilla.org/supports-string;1"].createInstance(Components.interfaces.nsISupportsString); var copytext=maintext; str.data=copytext; trans.setTransferData("text/unicode",str,copytext.length*2); var clipid=Components.interfaces.nsIClipboard; if (!clip) return false; clip.setData(trans,null,clipid.kGlobalClipboard); } alert("Following info was copied to your clipboard:\n\n" + maintext); return false;}//-->
Thank you very much for the quick response. This is FireFox 3.0.3 and yes it is a permission issue. I am going to implement the clipboard functionality that was given in the excel copy n paste example to handle the copy in FireFox and other browsers.
At a first glance, this looks like a permissions problem. It looks like the browser isn't permitting access to the clipboard.
What version of FireFox?
