165
Setting an Inital Value to WebCombo
I need to have the WebCombo display a initial value when the web page loads. The user can either proceed or change the value to one that they desire from the combo box.
Thanks in advance.
  • 370
    If you're binding the combo to a datasource then you can set the default value in the DataBound event.
    Protected Sub cboData_DataBound(ByVal sender As Object, ByVal e As System.EventArgs) _
      Handles cboData.DataBound
      With DirectCast(sender, WebCombo)
    If Not IsPostBack Then
    .SelectedRow = .Rows.Item(0)
    End If
      End With
    End Sub
    Otherwise you can just set the DisplayValue property to whatever value you want to display.
