Some of the grid cells are outputText, but I need to format them as currency, date and so on. The only way to format them, is to use inputCurrency and so on. Of curse, I can set it as read only. The problem is that the inputCurrency draws it's own edge. Is a way to change inputCurrency edge to invisible and change it's backgroud color? Or is a way to use outputtext with format directly?
You can change the style of the input currency box by using the style attribute or the styleClass attribute of the <ig:inputCurrency> tag.
For example:
Using the styleClass attribute:
<ig:inputCurrency id="inputNumber1" styleClass="inputCurrency" />
StyleClass definition:
.inputCurrency { border: 0px; background-color: white; }
Using the style attribute:
<ig:inputCurrency id="inputNumber1" style="border: 0px; background-color: white; }
For more information regarding themes, styles and styleClasses, see http://help.infragistics.com/Help/NetAdvantage/JSF/2008.2/HTML/JSF_Designing_the_Look_and_Feel.html
I hope this helps you,
Pamela
