hi,
I am using checkbox in webgrid(columntype.checkbox).
whenever i am check/uncheck i need to catch value for some purpose.I dont known which event fires(client event) for this operation.
Plz help in this.
Thanks in Advance
AfterCellUpdate is the right event to use if you're checking on the client.
If you're checking server-side, any of the following events will do, depending on whether you want postbacks to occur automatically and when you want the check to be performed: UpdateCell, UpdateCellBatch, UpdateRow, UpdateRowBatch
Either way, check the Value of the cell in your checkbox column. Assuming your column's datatype is set to be boolean, the cell's Value will be true if the box is checked, and false otherwise.
UltraWebGrid1_AfterCellUpdateHandler(gridName, cellId)
thanks.
Same problem as you please some can give some information ?
How can get the checkbox value on server side ?
Regards
