I have a simple web form with just one WebTextEdit control on it. When the 'Enter' key is pressed inside the WebTextEdit control, the entire web form posts back.
However if I put two WebTextEdit controls on the web form, when the Enter key is pressed inside a WebTextEdit control, the web form doesn't postback anymore ??
That's crazy !
I use Infragistics WebDataInput Version=7.3.20073.1049
Any help is highly appreciated. Please look at the web form, it's very simple:
<%@ Register Assembly="Infragistics2.WebUI.WebDataInput.v7.3, Version=7.3.20073.1049, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.WebDataInput" TagPrefix="igtxt" %> <html> <head runat="server"> <title>Untitled Page</title> </head> <body> <form id="form1" runat="server"> <div> <igtxt:webtextedit id="WebTextEdit1" runat="server" style="z-index: 100; left: 64px; position: absolute; top: 56px"></igtxt:webtextedit> <%--uncomment the control below and the web form won't Postback anymore when Enter key is pressed ?? --%> <%-- <igtxt:webtextedit id="WebTextEdit2" runat="server" style="z-index: 100; left: 64px; position: absolute; top: 156px"></igtxt:webtextedit>--%> </div> </form> </body> </html>
</html>
Thanks for note about HideEnterKey as I was about to ask the same question.
Cheers, Rob.
All right, now I see your point. Thank you for taking the time to answer.
Please do following:
1. Replace WebTextEdit by asp:TextBox (you should get postback on enter)2. Replace 2 WebTextEdits by 2 aspx:TextBoxes (you should not get postback on enter)3. Submit a bug to Microsoft about "crazy PostBack" of asp:TextBox
Thank you very much for your answer however I'm not sure that you have understood the problem.
How can you explain, please read again:
- when the web form contains just one Infragistics control, there is a PostBack when press Enter
- when the web form contains two Infragistics controls, there is no PostBack when press Enter
WebTextEdit has nothing to do with that postback. That is default behavior of most browsers. It will happen with any <input>.
WebTextEdit has a special property to disable that feature of browser. So, you may use HideEnterKey=true
