115
Issue while selecting cells more than once
Hi, I seem to be having a problem while using the Ultrawebgrid. I've programmed it such that the entire column gets selected when a cell is clicked. My priority is data visualization, and I am not worried about editing data/updating data in the grid. My issue is this: once I am done selecting a cell and the column gets highlighted, I am not able to select another cell. This exception pops up: Microsoft JScript runtime error: 'igtbl_StateChange.base.init' is null or not an object Would be grateful if someone can indicate where I am going wrong. Is it some attribute that I have to set, or is it something more serious? Thanks a lot.
  • 28464
    This definitely is an issue, however it is a bit hard for us to advice further since we need to reproduce the problem first, and it really depends on your custom code for selecting the whole column on clicking a cell.
    I believe the fastest way to go from this point is to contact our dedicated Developer Support team directly, with a small subset of your project reproducing the issue - this way it will be much easier for them to figure out what is going on and hopefully advice better. Developer Support can be contacted via this link:
    http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
    Btw, are you by any chance using IE8 Beta? A search on the forums for "igtbl_StateChange.base.init" gets just one match
    http://forums.infragistics.com/forums/p/13751/50742.aspx
    and there IE8 is mentioned...
