1) In my InitializeLayout event for the UltraWebGrid, I have the following code:
e.Layout.Bands[0].Columns[10].EditorControlID = WebDateTimeEdit1.UniqueID;
e.Layout.Bands[0].Columns[10].Type = Infragistics.WebUI.UltraWebGrid.ColumnType.Custom;
2) The grid has two date values: 1) start_date and 2) end_date. The start_date has a read-only value. The value for the end_date can be set from selecting a value from the WebDateTimeEdit control. The end_date value varies based on what the start_date is.
3) In what client-side event would I be able to set the MaxValue for each row's display of WebDateTimeEdit control?
scenario:
for row1: start_date = 1/1/2008 -- on clicking the WebDateTimeEditControl, the MaxValue input should be = 1/10/2008
for row2: start-date = 2/1/2008 -- on clicking the WebDateTimeEditControl, the MaxValue input should be = 2/10/2008
CR
Looks great - thanks for sharing in public forums - this will surely be helpful for other people as well.
Please ignore.. This is now closed. Here's the resolution - a new javascript function for ClientSideEvents -- BeforeCellChangeHandler="ug_BeforeCellChange" :
var cell = igtbl_getCellById(cellId);
if (cell.Column.Key="end_date")
var row = igtbl_getRowById(cellId);
var editor = igedit_getById("WebDateTimeEdit1");
var dt = new Date();
dt = row.getCell(7).getValue(); //get start date
var newdt = new Date(dt.getTime() + 30*24*60*60*1000); //add 30 days to the start date
editor.setMaxValue(newdt);
