60
Placing an image in Template column of ultraweb grid
Hi All,
I have the below requirement in my project. I have a template column in which i have an image control. I need to populate the image control by dynamically providing the url. The column is a bound column and the url will be supplied from the bound dataset. Please find the code snippet i used below
  <igtbl:TemplatedColumn AllowResize="Free" BaseColumnName="IS_VALID" IsBound="true" Type="NotSet" Key="IS_VALID">
           <CellTemplate>
             <asp:Image ID="imgValid" runat="server" ImageUrl=<%# DataBinder.Eval(Container.DataItem, "IS_VALID")%> Visible="true"                AlternateText="No Image found" />
             </CellTemplate>
            <Header Caption="Validated" Title="IS_VALID">
             <RowLayoutColumnInfo OriginX="4" />
              </Header>
               <Footer>
                 </Footer>
   </igtbl:TemplatedColumn>
The issue I am facing is the column gets populated with the image url insted of the image. Any help on this will be appreciated
  • 28464
    Weird, the syntax looks good. The only thing that may cause problems is that the ImageUrl value is not inside quotes (single quotes), .e.g.
    ImageUrl='<%# DataBinder.Eval(Container.DataItem, "IS_VALID") %>'
    In case this still does not work, you can try with plain HTML control instead of a server side one
    e.g.
    <img src='<%# DataBinder.Eval(Container.DataItem, "IS_VALID") %>' />
