Hi all,
I have put dropdownlist control inside the WebGrid.
what i want to do is, if i select the Employee ID from the dropdownlist , it should display the corresponding EmployeeName in the label which is
placed inside the Gird. when i do this, its showing the following error messages.
1) if i select the employeeid from dropdownlist, its showing error like "MicrosoftJScriptRuntimeError:'ChildNodes.Length' is null
or not an object".
2) if i click any one of the cells in the grid, its displaying the error like "MicrosoftJScriptRuntimeError: igtbl_statechange.base.init is
null or not an object".
Can anyone tell me how to solve this problem?
Thanks in Advance.
What version of Internet Explorer? If you're using IE 8, then this seems to be a compatibility issue, since this browser version is still pre-release. The following thread has more information:http://forums.infragistics.com/forums/p/11645/44043.aspx#44043
If you're using another version of IE, then this will likely require more in-depth research. In this case, I suggest that you submit a support request so that a Developer Support Engineer can investigate.
As for video tutorials, we have online, on-demand training courses available for purchase.
I am using Internet Explorer and do you have any video tutorial to understand about webgrid.
What browser are you using? This sounds familiar, but I can't find details in a quick search.
