510
WebDateChooser Value Changed, not changing?
OK - there must be an easy solution here that I am not seeing.  I have a WebDateChooser control.  I set the AutoPostBack for ValueChanged to true and set a breakpoint in the On_ValueChanged server-side event.  However,when I run and change the date, thereby triggering the On_ValueChanged event, the date of the control is Today's date - which I set in the PageLoad event as a default.
What obvious little detail am I missing here?  I am on Visual Studio 2005, using Infragistics 8.2 CLR 2.0.
Thanks in advance,
Dan
  • 510
    Verified Answer
     Never mind, I'm an idiot and it's been a long week.
    Since I don't mind poking fun at my own blunders, here's what happened.  My chooser is in a user control for my menubar.  I set the date to DateTime.Today in PageLoad for the user control.  I did NOT do this thru a If (!Page.IsPostBack) construct, hence everytime I posted back to the server I reset the chooser to DateTime.Today.
    Once I set the control property to not allow nulls, and took out the initialization code all is well.  Did I say it's been a long week?
    D.
