25
WebNumericEdit - Formating problems with UltraWebgrid
 I'm using a ultrawebgrid that contains numbers with 2 decimals. For editing the numbers i'm using a webnumericedit with datamode double and culture dutch since the users will all be dutch.
The ultrawebgrid has 3 colums. 1 Column is hidden, 1 column cannot be edited. The column to be edited has the format ###,###,##0.00, type custom and datatype System.Double.
The format for the numbers in the grid works as it should. When i click on the cell the webnumericedit displays the format correct, but when i click on it the second time the format is suddenly englisch and not dutch. For example. 100.000,12 is dutch format. The first time i click on the cell is displays 100.000,12 but when i edit the cell the second time the number is 10000012. It is as if is forgets that is should be dutch format.
If i change the value to 100.000,12 and save the record, there is no problem. The value given back to class bound to the grid is 100000.12
Can anybody tell me what's happining?
I'm using asp.net with vb.net.
here is my code:
<igtxt:WebNumericEdit ID="EditC" runat="server" BackColor="#CCFFCC"
Culture="Dutch (Netherlands)" Font-Size="XX-Small" Height="20px"
MinDecimalPlaces="Two" ValueText="000" Width="79px">
</igtxt:WebNumericEdit>
<igtbl:UltraWebGrid ID="grdGD" runat="server" Height="280px"
Width="280px" TabIndex="1">
<bands>
<igtbl:UltraGridBand AllowAdd="No" AllowColSizing="Fixed"
AllowColumnMoving="None" AllowDelete="No" AllowRowNumbering="None"
AllowSorting="No" AllowUpdate="Yes" CellClickAction="Edit" Expandable="No"
FixedHeaderIndicator="None" GridLines="Both" GroupByColumnsHidden="Yes"
RowAlternateStyling="False" RowSelectors="No" RowSizing="Fixed"
SelectTypeCell="None" SelectTypeCol="None" SelectTypeRow="None">
<addnewrow view="NotSet" visible="NotSet">
</addnewrow>
<Columns>
<igtbl:UltraGridColumn AllowGroupBy="No" AllowNull="False" AllowResize="Fixed"
AllowRowFiltering="False" AllowUpdate="No" BaseColumnName="Type"
CellButtonDisplay="Always" CellMultiline="No" Format="" IsBound="True"
Key="Type" SortIndicator="Disabled" Type="Custom" Width="130px"
EditorControlID="">
<HeaderStyle BackColor="Silver" />
<CellButtonStyle BackColor="Silver" Wrap="True">
</CellButtonStyle>
<Header Caption="Cluster" FixedHeaderIndicator="None">
</Header>
</igtbl:UltraGridColumn>
AllowRowFiltering="False" AllowUpdate="Yes" BaseColumnName="Amount"
CellMultiline="No" DataType="System.Double" Format="###,###,##0.00" IsBound="True"
Key="Amount" SortIndicator="Disabled" Width="80px" EditorControlID="EditC"
Type="Custom">
<CellStyle HorizontalAlign="Right">
</CellStyle>
<Header Caption="€/#">
<RowLayoutColumnInfo OriginX="1" />
</Header>
<Footer>
</Footer>
<igtbl:UltraGridColumn BaseColumnName="Sortorder" Hidden="True" IsBound="True"
Key="Sortorder">
<Header Caption="Sortorder">
<RowLayoutColumnInfo OriginX="2" />
</Header>
<Footer>
</Footer>
</Columns>
</igtbl:UltraGridBand>
</bands>
<displaylayout
allowupdatedefault="Yes" bordercollapsedefault="Separate" name="grdGD"
rowheightdefault="20px" rowselectorsdefault="No" stationarymargins="Header"
stationarymarginsoutlookgroupby="True" tablelayout="Fixed" version="4.00"
usefixedheaders="True">
<framestyle backcolor="Window" bordercolor="InactiveCaption"
borderstyle="None" borderwidth="1px" font-names="Microsoft Sans Serif"
font-size="8.25pt" height="280px" width="280px">
</framestyle>
<pager minimumpagesfordisplay="2">
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<borderdetails colorleft="White" colortop="White" widthleft="1px"
widthtop="1px" />
</PagerStyle>
</pager>
<editcellstyledefault borderstyle="None" borderwidth="0px">
</editcellstyledefault>
<footerstyledefault backcolor="LightGray" borderstyle="Solid" borderwidth="1px">
widthtop="1px" />
</footerstyledefault>
<headerstyledefault backcolor="LightGray" borderstyle="Solid"
horizontalalign="Left">
widthtop="1px" />
</headerstyledefault>
<rowstyledefault backcolor="Window" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" font-names="Microsoft Sans Serif" font-size="8.25pt">
<padding left="3px" />
<borderdetails colorleft="Window" colortop="Window" />
</rowstyledefault>
<groupbyrowstyledefault backcolor="Control" bordercolor="Window">
</groupbyrowstyledefault>
<groupbybox>
<boxstyle backcolor="ActiveBorder" bordercolor="Window">
</boxstyle>
</groupbybox>
<addnewbox>
<boxstyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid"
borderwidth="1px">
widthtop="1px" />
</boxstyle>
</addnewbox>
<activationobject bordercolor="" borderwidth="">
</activationobject>
<filteroptionsdefault>
<filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px" height="300px"
width="200px">
<padding left="2px" />
</filterdropdownstyle>
<filterhighlightrowstyle backcolor="#151C55" forecolor="White">
</filterhighlightrowstyle>
<filteroperanddropdownstyle backcolor="White" bordercolor="Silver"
borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px">
</filteroperanddropdownstyle>
</filteroptionsdefault>
</displaylayout>
</igtbl:UltraWebGrid>
