25
UltraWebGrid ValueListSelChangeHandler
How can i give a new value on a grid cell when i select item from ValueList(this is another column)
  • 28464
    The key here is using the client side ValueListSelChangeHandler client-side event - it gets fired whenever you are changing the selection from the dropdown for the respective column. Inside the client-side event handler you get three parametes - gridID, valueListID and cellID. You can get the dropdown instance from valueListID and get its selectedindex - and then use the client-side API of the grid to change cell values in other columns  based on the selection in the first one.
    Example:
     <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" DataSourceID="AccessDataSource1"
            Height="200px" OnInitializeLayout="UltraWebGrid1_InitializeLayout" Width="325px">
            <Bands>
                <igtbl:UltraGridBand>
                    <HeaderStyle Height="50px" />
                    <Columns>
                        <igtbl:UltraGridColumn BaseColumnName="ReorderLevel" DataType="System.Int16" IsBound="True"
                            Key="ReorderLevel" Type="DropDownList">
                            <Header Caption="ReorderLevel">
                                <RowLayoutColumnInfo OriginX="8" />
                            </Header>
                            <Footer>
                            </Footer>
                            <ValueList>
                                <ValueListItems>
                                    <igtbl:ValueListItem DisplayText="Text1" DataValue="1" />
                                    <igtbl:ValueListItem DisplayText="Text2" DataValue="1" />
                                    <igtbl:ValueListItem DisplayText="Text3" DataValue="1" />
                                </ValueListItems>
                            </ValueList>
                        </igtbl:UltraGridColumn>
                        <igtbl:UltraGridColumn BaseColumnName="Discontinued" DataType="System.Boolean" IsBound="True"
                            Key="Discontinued" Type="CheckBox">
                            <Header Caption="Discontinued">
                                <RowLayoutColumnInfo OriginX="9" />
                            </Header>
                            <Footer>
                            </Footer>
                    </Columns>
                    <AddNewRow View="NotSet" Visible="NotSet">
                    </AddNewRow>
                </igtbl:UltraGridBand>
            </Bands>
            <DisplayLayout BorderCollapseDefault="Separate" Name="UltraWebGrid1" RowHeightDefault="20px" AllowUpdateDefault="Yes"
                Version="4.00">
                <ClientSideEvents ValueListSelChangeHandler="cellUpdate" />
                <FrameStyle BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana" Font-Size="8pt"
                    Height="200px" Width="325px">
                </FrameStyle>
                <Pager>
                    <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                        <BorderDetails ColorLeft="White" ColorTop="White" />
                    </PagerStyle>
                </Pager>
                <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
                </EditCellStyleDefault>
                <HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid">
                </HeaderStyleDefault>
                <RowStyleDefault BackColor="White" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px"
                    Font-Names="Verdana" Font-Size="8pt">
                    <Padding Left="3px" />
                </RowStyleDefault>
                <AddNewBox>
                    <BoxStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                    </BoxStyle>
                </AddNewBox>
                <ActivationObject BorderColor="" BorderWidth="">
                </ActivationObject>
            </DisplayLayout>
        </igtbl:UltraWebGrid>
        <asp:AccessDataSource ID="AccessDataSource1" runat="server" DataFile="~/App_Data/Nwind.mdb"
            SelectCommand="SELECT * FROM [Products]"></asp:AccessDataSource>
             function cellUpdate(gridID, valueListID, cellID)
                 var valueList = document.getElementById(valueListID);
                 if (valueList.selectedIndex == 0) {
                     // do something.. like check checkbox
                 else {
                    // uncheck checkbox
         </script>
    A very good thread that can help you with CSOM and how to change values is this one:
    http://forums.infragistics.com/forums/p/1156/11700.aspx#11700
    HTH,
