hi,
iam using infragistics 2008
i used gridview to display the data
iam using image in link tag and iam calling one method
in that method i want to get the rowdata based on the user selection.
in normal jsf dataTable we have getDataTable().getRowData()
but in gridView can i have that Option..?
can we get the data of that row and typeCast to businessObject..?
pls reply,
thanks in advance
Yes, you should use SmartSubmit as described above. If you're really unsure how to proceed you might consider having an Infragistics consultant help you. You can contact them at sales@infragistics.com
My jsp page looks like the following
When I click on command link youPaid I should be able to pass claimNumber(unique key) or the row id like the rownumber to my managed bean depending on which I have to display another grid. I do not want to implement check box. Should I use ig smartsubmit?
"text/html; charset=ISO-8859-1"
"http://ko.infragistics.com/faces/netadvantage"
"http://jakarta.apache.org/struts/tags-tiles"
"outputText"
"medicalGridView"
"text3"
"gridViewRenderer13"
"2"
="#{medicalClaims.youPaid}"
h:commandLink
"Prescription Claims"
"drugGridView"
"text4"
="#{DATA_ROW.prescriptionClaims}"
"youPaidDrug"
"gridView"
"dentalGridView"
"text5"
"gridViewRenderer15"
"youPaidDental"
"fsaClaimsGridViewRenderer"
"false"
Usign the version 9.1, yuo can trap the cell click using CSOM and get the value inside the rows on mouse click.
Please refer the following sample:
http://www.componentsforjsf.com/CSOMExamples/faces/examplePages/GridCSOMOne.jsphttp://www.componentsforjsf.com/CSOMExamples/faces/examplePages/GridCSOMTwo.jspIt gives you a way what JIM has suggested above. The above sample gives you data on client side. You can put use some id from the row into the hidden field and using the smartRefresh you can process it on server.
Thank you.Roshan
No as per our requirements it is not possible to use checkbox. Do you have an example of how to use it the other way?
Hi:
As Swetha points out, you can use a check box for row selection: with that you will be able to grab the selected row or rows and cast a BO from them.
Alternatively, if you use version 9.1 you can capture the row click on the client-side via our CSOM, and pass it to the server via our AJAX "smart submit" feature.In most cases, the easiest way to do what you want - or at least, what I think you want - is to capture the row click via CSOM and them put something (usually the primary key of the row) into a hidden field. Then send that field to the server via Smart Submit and have the server do any business level processing you need.
If your new to the product, this might seem odd, but its actually quite easy and required very little coding.
Best,Jim
