I am using the WebdateChooser, however for some objects i need to fixed the day to the 1st of the month. The user can't changed this.
I would like to have the following:
* The same layout, except the user can't change the Day (So only month and year change) with displaying the Day (1,2,3,4....28, 29, 30,31)
* Or leave the Day chooser out completely
How do I do that?
re bert
Hello Viktor,
I had not replied, however this is working great.
Hi Bert,
WebDateChooser does not support similar feature. However, since it raises various events, it it relatively easy to implement. Below example will keep 1st day of month regardless to what user entered.
<script type="text/javascript">function WebDateChooser1_ValueChanged(oDateChooser, newValue, oEvent){ if(!newValue) return; oDateChooser.setValue(new Date(newValue.getFullYear(), newValue.getMonth(), 1));}</script>
<igsch:WebDateChooser ID="WebDateChooser1" runat="server"> <ClientSideEvents ValueChanged="WebDateChooser1_ValueChanged"></ClientSideEvents></igsch:WebDateChooser>
