165
UltraWebGridExcelExporter Not Showing Save Dialog
What I'm doing here is using code to determine if there are 300 rows in my dataset.  If there are, then I want to create the new WebGrid object and use that for the Excel export.  If there are not 300, then I use the grid that is visible on the page.  I'm doing this for performance reasons because the users can have grids with hundres, and thousands of rows which take quite a while to render on the page.  When there are 300 rows, the save dialog box never comes up.  Please help!
<igtblexp:UltraWebGridExcelExporter ID="gridExport" runat="server" DownloadName="Results.XLS">
</igtblexp:UltraWebGridExcelExporter>
protected void SaveExcel(UltraWebGrid grid)
UltraWebGrid ug = new UltraWebGrid();
if (Session["reportGrid"] != null)
if (((DataSet)Session["reportGrid"]).Tables[0].Rows.Count > 300)
               ug.DataSource = (
DataSet)Session["reportGrid"];
               ug.DataBind();
               gridExport.Export(ug);
else
          gridExport.Export(grid);
