I am seeing some strange behavior recently wit the Grid Designer where is losing properties. The scenario goes like this:
I realize that better practicemay be to code the layout in the Initialize Layout, but this behavior appear to be so off that I am concerned that I may have a more serious issue. At the moment, with this nbehavior, the quick design functionality is nonfunctional. Note that while I have in the past had instance where grids lostt properties I have never seen this behavior where you simple can not get a property change to save.
Has anyone else seen this behavior??
Thanks in advance for all help.
Neil
