665
Problem in Drag ang drop with WebTree
I have used a webtree,its working fine with child nodes but i have a broblem its not working with sibling nodes.
For ex,
 My Root node is Root1,It having 3 child nodes Parent1,Parent2&Parent3.The Parent nodes also have a child nodes.When i drag the Parent3 node and drop between Parent1 and Parent2 .its become a child of Parent1 but i  want its become a sibling node of Parent1 node.
Can anyone help me..
  • 7694
    Well actually what happens is that on the client a NodeDrop event is fired and you can customize whether a node becomes a child or a sibling of the destionation node there. For example, please take a look at the following sample
    There you will see the following code that actually makes the node a child of the destination node
            function UltraWebTree1_Drop(oTree, oNode, oDataTransfer, oEvent){
    var sourceNode = oDataTransfer.sourceObject;
    if(!oNode.isChildOf(sourceNode))
    oNode.addChild(oDataTransfer.dataTransfer.getData("Text"));
    oNode.setExpanded(true);
    if(sourceNode)
    sourceNode.remove();
    return false;
    So I believe starting from this sample and tweaking the Drop even will lead you to the right path (e.g. not use addChild for the destionation node, but rather for its parent)
